Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1970 - 1973 Overlander
Old 01-03-2016, 01:22 PM   #1
Raleigh , North Carolina
Finally took the leap. . .
I've been reading the forum for some time now and decided to look for a trailer. After searching for several months with the usual dead ends, I finally took the leap (maybe off the deep end) and hauled one 4 hours home last week.
This unit has the usual leaks: bath floor is weak, few wet spots behind cabinets, saw one drip from the center vent.
It never had an AC unit, so one of the previous owners had fab-ed a window unit, which we ripped out before hauling it down the road. Fortunately, all the windows are intact and functional, except the the one the AC unit was it. The rivets that hold the "hinge" in place broke while trying to remove the unit.
The carpet has been removed but for the most part the interior is complete and in good shape. I was told that all electronics work, however, due to where we met to look at the trailer this couldn't be verified. I have a 50 amp service to connect to but need to get an adapter for the 30 amp umbilical cord. It has had a "newer" converted installed, but I haven't looked into what brand it is yet.
The body is is OK condition with a few dents to be addressed once the interior panels are out. The only one that has me worried is on the curb side front (see pic), it is in a seam. I can deal with a not-so-perfect exterior, however I can't deal with an seam I can't seal. The clear is starting to oxidize in places so I suppose I will have the pleasure of removing that and perhaps polishing.
The belly pan will likely be replaced as well. There is a section missing under the fresh water tank (I can't explain why), but this allowed be to peak inside and it appears that while the lips holding the tank are shot, the frame is in decent condition. Of course that could change once the floor is up.
I would go on about what I have planed for it. . . but Ill take it one step at a time haha. First priority is to get a new floor in, take a ton of pics along the way, and then figure out how to seal everything. The material used on the exterior seams is going to be a pain to remove, but I will cross that bridge in time.
Happy New Year
ID:	255025   Click image for larger version
ID:	255027   Click image for larger version
ID:	255029   Click image for larger version
ID:	255031   Click image for larger version
ID:	255033   Click image for larger version
JEdge is offline   Reply With Quote
Old 01-04-2016, 03:09 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Congrats and welcome to the insanity...I mean FUN!
Old 01-04-2016, 04:21 PM   #3
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Welcome and Congratulations !!!
J Nelson
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 01-04-2016, 05:23 PM   #4
brokeboater's Avatar
2013 25' Flying Cloud
Crystal River , Florida
Good luck. Nice looking rig.
brokeboater is offline   Reply With Quote
Old 01-04-2016, 05:39 PM   #5
ericpeltier's Avatar
Superior , Colorado
Love the shape of the '70s Streamlines. Congrats!
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 01-05-2016, 07:08 AM   #6
Thanks folks. I can't wait to start tearing it apart and cleaning it up.
What is everyone using to remove the old sealant from the exterior seams? I assume the aircraft stripper would work to some extent. Which makes me think that before the interior goes back in all exterior work should be completed to insure everything is sealed properly. Is that logical?
Just trying to get my ducks in a row.
Old 01-05-2016, 01:15 PM   #7
1973 31' Excella 500
Calgary , Alberta
Welcome. The pics look so much like our 73 Excella. Yours look to be better in the pics than ours. Ours is currently undergoing a complete shell off rebuild.
Have fun and don't burn yourself out by doing to much at one time.
DaKs is offline   Reply With Quote
Old 01-05-2016, 01:21 PM   #8
belen , New Mexico
GREAT! congrats. It will love you back. I promise!
alantbird is offline   Reply With Quote
Old 01-05-2016, 09:52 PM   #9
1971 31' Sovereign
Temple , Texas
Lots of work ahead, but worth the effort (IMHO). We're in the process of replacing all of the copper plumbing in our 71 Sovereign with PEX. Not fun, but badly needed.
TxDave is offline   Reply With Quote
Old 01-06-2016, 04:45 PM   #10
Did you buy the fancy PEX tool or are you using the cheaper one?
Old 01-06-2016, 11:16 PM   #11
1971 31' Sovereign
Temple , Texas
I paid about $40 for cinch / clamping tool at Lowe's. Seems to work just fine.
Old 01-07-2016, 07:58 AM   #12
I think I will run PEX instead of cooper when I get to that point. Taking notes from this thread http://www.airforums.com/forums/f36/...-38289-65.html Id like to make everymore more serviceable once it is put together. Lots of great info (and skill) on that thread
Old 01-09-2016, 02:01 PM   #13
1972 27' Overlander
Denver , North Carolina
I am almost finished with my 72 after a two plus year shell on resto. Don't cheap out. Do it right the first time - replace the bath floor and c channel. Regardless of how it looks now it does need to be replaced. None of it is hard to do - just have a plan and go for it. You will learn much about using a drill to remove rivets. If something does not come apart after you removed all the rivets - you missed one or two go back and look.
Take many many pictures and save everything you will need something eventually.
Ping me if you have questions.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 01-10-2016, 08:32 PM   #14
Thanks for the input. I'm formulating my plan of attack now. I'd like to secure a shelter for the trailer before I dig in but that may be something I have to keep my eye out for as I work. I'm sure I'll be pestering you with questions before too long haha
Old 01-10-2016, 09:02 PM   #15
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
There is a reason why that method is the cheaper of the two.... More prone to leaks. With the crimping tool you get a uniform reduction around the ring sealing the barbed end better. With the cinch rings you are essentially putting hose clamps that are meant for it but certainly do not distribute the force equally. Another disadvantage to cinch rings are that you do not have a reduction gauge to ensure the proper amount of reduction, more reduction is actually bad also. It will begin to reduce the wall thickness and will tear near the ring when slightly bent. The crimping tool comes with a "go / no-go" gauge. That being said, you can use either tool, but like the ole' saying goes "you get what you pay for".
If your looking for convenience and money is not an option maybe Sharkbite fittings are the way to go. Just slip them on and your done, no reducing needed.
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
I took the leap and bought a 1987 Excella! carolynt General Repair Forum 1 09-26-2015 07:55 AM
Oregon Newbies taking the leap Climber Member Introductions 13 01-02-2015 06:25 PM
Finally took out the summer project-'68 GT Randy Gates 1965 - 1969 Globetrotter 9 10-18-2010 01:33 PM
Finally took the plunge - 1971 KATYBELLE 1970 - 1978 Globetrotter 13 10-06-2010 11:03 AM
Finally took the plunge billberk 2007 Safari SE 16 07-16-2007 09:48 AM
