03-01-2016, 12:01 PM
#221
1966 26' Overlander
Woodstock
, Georgia
test photo rotation
03-02-2016, 07:37 PM
#222
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Alan,
Did you do that from within the Airforums? or rotate it +90 degrees then re-upload it?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
03-03-2016, 03:59 PM
#223
1966 26' Overlander
Woodstock
, Georgia
Rotated on my laptop saved as jpeg
07-31-2016, 05:26 PM
#224
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I finally was able to take some time off from work and devote it to the trailer. The belly is now all enclosed, the holding tank/dump valve plumbing installed, and the fresh water plumbing is installed as well.
Finally, I can start on the interior. In that direction I removed all the spare parts sitting in the trailer, and gave the floor two thick coats of spar varnish on top of the West System Epoxy the plywood was originally coated with. At least if it leaks, there won't be any floor damage!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
08-01-2016, 04:41 PM
#225
1966 26' Overlander
Woodstock
, Georgia
ready to see this project! Keep up the good work
11-25-2016, 03:33 PM
#226
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I had some more vacation time and was able to get some work done on the trailer. The new interior wiring is now in. The second layer of Prodex is going in along with the original interior skins. Initially I planned to replace all of the interior skins with new aluminum, but finding .04" in a 17' sheet was difficult. So, the new idea is to install the old skins and paint them. If my wife likes the look, we will go with that. If she doesn't, I can find thin 5052 in any length I want which I will use as a vainer over the now painted old skins.
Attached are some pictures as proof that I actually worked on the trailer. This project is taking forever! What I don't have finished by Springtime, will be completed by Woodland up in Grand Rapids.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-25-2016, 03:43 PM
#227
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
OK, I am well and truly puzzled. The pics are properly oriented in my computer prior to uploading, but then I get flipped on my head in the final version of the post. Grrrrr. Or maybe I should be happy I have a gravity defying Airstream. Just think how great my towing milage will be!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-26-2016, 05:51 AM
#228
1989 29' Excella
Tyrone
, Georgia
Awesome work Craig.
11-26-2016, 09:42 PM
#229
Central
, Mississippi
Awesome work while standing on your head. Did you move to Australia 'down under'?
12-21-2016, 05:57 PM
#230
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
A bit more accomplished over the past week. The old interior panels are clean and re-installed. The aluminum end cap kits I purchased from Colin Hyde are buck riveted together and clecg'd in place awaiting final trim fitting. I'm waiting for an estimate to spray paint the interior a uniform silver color from our local helicopter repair shop which has a monster sized paint booth.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
12-21-2016, 05:59 PM
#231
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
More pics of riveting end caps.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
12-22-2016, 05:52 AM
#232
1999 27' Safari
Stone Mountain
, Georgia
Amazing work Craig. I can't wait to see it one day!
_______________________________
Beth Wallace & Chris Sanor
1999 Safari 27'
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
12-23-2016, 01:31 PM
#233
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
We were able to install the end cap kits purchased from Colin Hyde yesterday afternoon. The kits went together easily, but did require a bit of trimming to fit around the window openings fore and aft.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-20-2017, 04:52 PM
#234
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
It's been a long project. After about three years working on it myself, the project was at the point of needing custom cabinetry made. I have the tools, but not the time. After some searching we selected Woodland Travel Center in Grand Rapids, MI to do the work. Gary did a fantastic job on the cabinets and other items. We can't speak highly enough of him and his attention to detail.
Below are the final pics of the project. We camped several nights in the trailer prior to bringing it back to Atlanta and did have any significant camping issues.
Thanks guys!
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-20-2017, 04:59 PM
#235
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
A few more pics
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
11-21-2017, 09:20 PM
#236
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Thanks for posting the photos. Absolutely superb design and build quality by you and Woodland.
Dan
12-06-2017, 11:39 AM
#237
1970 27' Overlander
Highland
, Indiana
Hi ,
Graig The Overlander looks Wonderfull!!! Glad that you were able to finish her !
She looks Beautiful that gives me the motivation that I need to finish mine I have the same problem that you did not enough time!
