Old 09-20-2017, 07:55 PM   #1
Rockton , Illinois
Door and screen door adjustments
Has any one ever had to adjust either of the 2 doors?
I put new gaskets on the screen door and things got a little tight.
The main door is off as well. I will try to post picks tomorrow.
I'm not having any luck on searching as to what to do.
Just another issue of owning a AS LOL..
Thanks for any input as always
JBKNOWSO
jbknowso is offline   Reply With Quote
Old 09-20-2017, 08:01 PM   #2
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
There is a YouTube Video from the AS factory demonstrations on how to adjust the screen/outer door...
HHPJ is offline   Reply With Quote
Old 09-20-2017, 08:11 PM   #3
2008 25' Safari FB SE
Frederick , Maryland
Google "airstream door adjustment" it is a 13 minute YouTube video that will explain it.
VWill is offline   Reply With Quote
Old 09-20-2017, 08:39 PM   #4
Rockton , Illinois
Will do. Thanks Vwill.
Old 09-20-2017, 08:40 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
https://youtu.be/j7-PprGeESE
MICHAEL
Old 09-20-2017, 09:41 PM   #6
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Adjusted our door loosely based on this video. Didn't take too much force or skill, I regret waiting months to do it. I also find that not over tightening the stabilizer jacks helps the door latch operation. When we got our new-to-us 2005 Safari, you could see 1/2" gap at the top of the door.
DaveMc is offline   Reply With Quote
Old 09-20-2017, 09:45 PM   #7
1979 23' Safari
Wayland , New York
Before you bang on the door, give the new gasket a week to set in.
Old 09-20-2017, 10:28 PM   #8
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Yes, the gaskets will seat better after a little while.
youngpeck is offline   Reply With Quote
Old 09-21-2017, 11:28 AM   #9
White Bear Lake , Minnesota
Did anyone notice in the video the worker measuring on a door. He ran the tape measure over something to take the measurement. That is not the way to take an accurate measurement. Little wonder..................
lyleapgmc is offline   Reply With Quote
Old 09-21-2017, 01:26 PM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
If your door is also bent and loading the gasket you might look at my method of re contouring the door. My door had blown open while traveling and flattened out a bit.
Sorry I can not post pictures directly as I have reached my limit so I hope will help. Post 3 of this tread.
http://www.airforums.com/forums/f4/b...me-139862.html
Do not use the block of wood method as you can easily over correct or crease the door.
2004 Excursion 4x4
Old 09-21-2017, 04:41 PM   #11
dznf0g's Avatar
Oswego , Illinois
I used the block of wood method 7 years ago. Still fits fine. Good method, but is totally dependent on operator skill level. Back in the "good ole days", car doors were adjusted same way. Not necessary anymore.
-Rich-
Old 09-21-2017, 11:27 PM   #12
Rockton , Illinois
Thanks everyone for all your great advice. The screen door is a wrap. The main door is still not fixed. I'll post pics tomorrow. Basically as you look at the door from the out side, the door is hitting the shell on the top right when you close it. There is 1 washer in the hinge. I'm guessing that's part of the issue. Is that normal guys and gals?
Old 09-21-2017, 11:31 PM   #13
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
My 2017 had a 1/4 inch gap at the top of the main door. You could see daylight at the right angle from inside the trailer.
None of this worked and I had to take it to the dealer and they spent almost a month waiting for AS mothership to explain and walk them through how to fix it.
Finally they figured it out. They had to take the door out, redrill the high holes and align the dorr an d bolt it back up. It works great now.
Troutboy
Troutboy is offline   Reply With Quote
Old 09-21-2017, 11:34 PM   #14
Rockton , Illinois
That's crazy. Your scaring me
Equalizer hitch adjustments Raptorrider2001 Hitches, Couplers & Balls 4 09-22-2017 11:45 AM
Day/night shade tension adjustments? cwf General Interior Topics 3 03-15-2013 09:39 AM
30 ft. Classic Limited pocket door adjustments patrick p General Interior Topics 9 05-25-2012 05:12 PM
results of CAT Scales and WD hitch adjustments funkill Hitches, Couplers & Balls 10 07-11-2009 07:35 PM
Tappan Oven adjustments srgntpepper Stoves, Ovens & Microwaves 0 12-07-2003 07:15 PM
