Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1965-1969 Sovereign
Old 08-03-2017, 11:11 AM   #1
Rockton , Illinois
69 Sovereign?
Ok, I looked at this today and was wondering if this is indeed a 69 Sovereign? Can anyone tell me?
I saw these letters and numbers on the side.
K260 FH
131T 90220
Thanks for your help here's some pics too [emoji106]
ID:	291217Click image for larger version
ID:	291218Click image for larger version
jbknowso is offline   Reply With Quote
Old 08-03-2017, 11:56 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Looks like a 69. Look carefully at the serial # right on the badge right below where it says Land Yacht (that denotes a trim grade, International was the other choice back then). Here is how to decode it:
Identification Numbers for 1969 to 1980
1. Locate and write down the nine- or 10-digit serial number from the A-frame.
2. Read the digit in the first position to determine if it is an "I," indicating an International model, an "E," indicating an Excella model, or an "L," indicating a Land Yacht model. Read the digits in the second and third positions to see the length in feet. Read the digit in the fourth position to see a code for the floor plan, detailed on the Airstream publication listed in the References section.
3. Read the digit in the fifth position to identify the final digit of the model year. Read the digit in the sixth position to determine if it is an "S," indicating manufacture in California, or a "J," indicating manufacture in Jackson Center, Ohio. Read the final three digits to identify a unit built in the 1960s or four digits to identify a unit built in the 1970s.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
sovereign
1974 Sovereign Land Yacht :: 1974 Airstream Sovereign Land Yacht MyTwinkie Airstream Registry Discussions 0 01-13-2012 08:51 AM
Sovereign :: 1987 Airstream Sovereign tinkerinwv Airstream Registry Discussions 0 11-28-2011 12:12 PM
Sovereign :: 1960 Airstream Sovereign truckasaurus Airstream Registry Discussions 0 11-20-2011 11:53 AM
1973 Silver Sovereign 31! AIRSTREAM. LOW RESERVE S1973 Silver Sovereign 31! AIRSTREAM eBay Watch Airstreams on eBay 0 09-22-2011 11:20 AM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
