Old 09-26-2007, 04:32 PM   #15
Baltimore , Maryland
plastic is cheaper... cheaper means higher profit marigin... it's very simple. My vintage unit has metal hooks that lock the drawer shut when you twist the knob. Guess the profit margin wasn't so tight in 1962.
Old 10-21-2007, 06:01 PM   #16
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Originally Posted by peegreen
You could also install child safety devices that will prevent the drawer from opening more than an inch.
Well, I installed the child safety latches on my 05 Safari LS center drawer today. I got tired of picking up all the stuff that got dumped each time I reached my destination. (I have the center dresser drawer with twin beds model) Was previously using Velcro which really didn't work very well and made the dresser look ugly.
Took trailer out for a test and I am very happy with the results.
Got the kit from Lowe's for under $3.50. Took about 1/2 hour to install with my "superior" carpenter skills .
Anyway, thought I'd share it with you guys.
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 10-22-2007, 09:04 AM   #17
jzelle's Avatar
2006 28' Safari SE
Halifax , Nova Scotia, CANADA
Another solution
You can get self-closing full extension drawer slides from Lee Valley Tools. They actually pull the drawer closed in the last 2 inches of travel.
I have used these on additional drawers that I added on my Safari, and they work great.
They can be found here:http://www.leevalley.com/hardware/pa...=3,43614,43616
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 10-22-2007, 09:38 AM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The best drawers I had were in my 2001 Safari where when the knobs were pushed in, the drawer was locked.
On my Classic the drawer rails have a little metal high end at the front end of the rail. Technically when you open the drawers, you lift the drawer which allows the drawer to lift over the stop. The problem with this is two fold.
First if you don't lift the drawer at the end when you push it in, you bend the tab. Secondly if you hit a good enough bump the drawer will bounce in the rail and bounce over the stop. On rough roads it's not unusual to find at least 3 of the drawers slide open. I went back three times to the dealer's to fix it and the answer was to always bend the tabs on the rail back up. One day I'll add some latches that will provide a more positive catch to the drawers. Something on the order of the drawers under the Queen bed.
I'm not sure if A/S has changed that design in the subsequent years for the Classics, but it's very poor.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-22-2007, 09:47 AM   #19
richinny's Avatar
2011 34' Classic
the 2009 models will have an inflatable raft to put in the isle while traveling. just kidding :-)
Ricky
Old 10-22-2007, 09:50 AM   #20
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
If the drawers don't snap into place the the catches are broken, on our CCD the board the catches where attached too had come unnailed, might want to remove a drawer and take a look
Damon
Originally Posted by campadk
Dang! Our two drawers under the clothes closet in our 75th ejected during a short 30 minute haul to our storage place. Nicked the floor and chipped one of the drawers...
How can this be? Why doesn't AS have a stop to prevent this from happening? Is this something unique in the 75th or do other Airstreams have this issue. Surely this is something they should have thought about over the last 75 years!
Others be forwarned... a fix should be make before this happens to you!
damonbeals is offline   Reply With Quote
2007 bambi
Cabinet doors, drawers and hardware? ironfem200 General Interior Topics 5 07-09-2006 05:25 PM
Kitchen drawers-can they support weight? femuse Cabinets, Counter Tops & Furnishings 7 10-29-2004 06:13 PM
storage drawers on 345 howardann Exterior Storage Compartments & Access Doors 2 11-17-2002 04:27 PM
Layout of wardrobe & chest of drawers jeanarlene General Interior Topics 2 09-30-2002 08:40 AM
