Old 08-07-2015, 08:19 PM   #1
2015 16' Sport
Eugene , Oregon
Will this setup work for fridge fan?
I decided to replace the fridge fan on my Bambi sport 16. That fan system hanged down and blows air out the side ( there is no top vent). My RV service person replaced my fan with two nocturas per my request, but has the facing up. He insists that is better. Is that right? I would presume Airstream had a reason for hanging it the way they did. Does it matter the way my service guy did it?
New Fans Click image for larger version
Name:	ImageUploadedByAirstream Forums1438996509.017491.jpg
Original: Click image for larger version
Name:	ImageUploadedByAirstream Forums1438996738.652567.jpg
tjwoods1 is offline   Reply With Quote
Old 08-07-2015, 08:42 PM   #2
2007 22' International CCD
Fans laying flat may live longer. Less strain on bearings. Better airflow with them together like that.
KE4GNK/AE
Old 08-07-2015, 09:37 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, we mounted horizontal on ours but we have roof vent.
Seems as
Long as the fans move the air over the fins and "out" they should do fine.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-07-2015, 09:48 PM   #4
2015 25' Flying Cloud
Manheim , Pennsylvania
I don't think it will hurt to try, looks interesting. I've tried a couple of different things with fans and I am still not satisfied.
Youtube channel "Airstream Adventurers"
https://www.youtube.com/channel/UCW4...NOHJQUM1yyDLAw
Jukeboxfun is offline   Reply With Quote
Old 08-07-2015, 10:08 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
I have found that fans work much better when they pull the air rather than push it across the condenser. That requires placing them on the top side vent or roof vent for maximum efficiency.
Your placement will work, just not optimally.
BTW, I place these fans on 20-30 units a year........ most are Airstreams.
Old 08-07-2015, 10:12 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by lewster View Post
I have found that fans work much better when they pull the air rather than push it.......
That I accept as fact.
I read somewhere that pushing air with a fan causes a loss of about 1/3 of the cfm when compared with the same fan pulling air.
Old 08-07-2015, 11:00 PM   #7
Aluminum Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Pardon my Ignorance
Isn't one side of the fan pushing air and other pulling air - just asking?
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 08-07-2015, 11:23 PM   #8
Mission , Texas
Yes ...
There is more to push vs pull as more efficient than meets the eye. It has to do with the specific application. In this case I'm with Lew.
A potentially ridiculous case of push being more efficient is a turbo charger where the exhaust gas pushes a fan which in turn pushes combustion matter. Imagine trying to pull that ...
A questionable example of which is which, push vs pull, the central heat/air in a home. Is the fan blowing the air out to various locations, or pulling it from various locations? Or both ...
nrgtrakr is offline   Reply With Quote
Old 08-07-2015, 11:45 PM   #9
2015 16' Sport
Eugene , Oregon
Lester,
When you say you have found that the fans work much better when they pull the air rather than push it across the condenser, is that what happens when they are hung the way Airstream had installed them? Are they pulling air that way? (Like I mentioned, the 16' Sport has no top vent, it vents out the side only)
Old 08-07-2015, 11:45 PM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Keeping the fridge cool in the summer is a problem, especially when we are traveling all day. It may start out at 32 degrees in the morning but by the end of the day traveling is in the high 40's.
I am going to try to install 2 or 3 computer fans in the chimney at the top and see how this helps fridge performance.
Thanks for your helpful comment Lew.
Dan
Old 08-08-2015, 12:04 AM   #11
lewster's Avatar
Originally Posted by tjwoods1 View Post
Lester,
Nope. If you really want maximum efficiency from your fridge fans and only have side vents, attach the fans to the upper vent door.
This location pulls air across the condenser to moderate it's temperature, which is the whole reason for the fans.
Oh, and BTW, it's 'LEWSTER' :-))
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-08-2015, 12:10 AM   #12
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I mounted my fans under the fins but close enough that the pull or push efficiency difference should not be an issue.
http://www.airforums.com/forums/f425...ml#post1320168
My trailer has the roof opening which is a better chimney cavity than the side ported. I also have a larger exhaust fan mounted at the opening wired to a manual switch for truly hot days. I have only turned on the upper fan twice since the pictured mod was complete. Those were 110°+ days in the desert.
The pictured fans keep my reefer cold on the number 1 setting whenever its under 95°.
SeeMore is offline   Reply With Quote
Old 08-08-2015, 12:57 AM   #13
2015 16' Sport
Eugene , Oregon
Attach to the door like this?
Name:   ImageUploadedByAirstream Forums1439013413.807174.jpg
Old 08-08-2015, 01:27 AM   #14
lewster's Avatar
There ya go!
Work Platform for Roof Work Bubba John Roof 18 08-02-2015 10:16 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 10:27 PM
Prep Work vs Finish Work Nolavalkyrie Vintage Kin 5 10-03-2013 04:11 PM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 11:36 AM
Will my weight distrubution setup work on an AS? RV H-D Lady Hitches, Couplers & Balls 19 10-30-2010 06:52 AM
