Old 10-20-2015, 01:04 PM   #1
LAFAYETTE , Colorado
Which battery
Hi Folks, 16ft Bambi owner 2005, plan to boondock 2-3 days at a time.
Will run water pump, furnace in 55 degree night outdoor temps and above, detectors, maybe some LED lights. Nothing else.
Planning on a single 80 watt solar panel.
Which of the many glass matt battery groups should I need and any particular brand? Very important to keep the furnace going for the wife.
Thank you. Ty
TYPECK is offline   Reply With Quote
Old 10-20-2015, 01:12 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Furnace is a amp. hog - fan.
Why are you limited to only a 80 watt solar panel?
I use a 190 watt solar panel and 300 amp 6 volt AGM (x2) batteries.
This has worked out very well - same problem with wife.
With out AGM 6 volt batteries it wouldn't work.
Hate using generator! I boondock for the quiet - away from cities, etc.
Silver Hawk is offline   Reply With Quote
Old 10-20-2015, 01:15 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
X2 on the twin 6 volt batteries!
I personally use Rolls batteries.
Old 10-20-2015, 02:37 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, a pair of 6 volts, brand and construction of your choice.
MICHAEL
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
