Old 08-19-2014, 08:38 PM   #1
Oregon city , Oregon
What type of TV cable it use?
Hi everyone. I recently purchased a rg6 coaxial cable to plug on the outside tv cable plug which under the 30amp power plug. No mater how hard I try, it does not insert in to the little hole.
Eresan is offline   Reply With Quote
Old 08-19-2014, 08:46 PM   #2
2016 30' Classic
Erie , Colorado
Eresan the RG6 should have a metal connector on the end. If you look into the end of the connector you should see a bare metal copper wire. It needs to be straight. That wire inserts into the center hole of the connector on the outside of your trailer and then you tighten up the nut on the cable screwing it onto the cable connector on the trailer.
If the center wire is bent you won't be able to put them together. If you can't straighten it out then the cable will need to have the end trimmed off and a new coax connector installed.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
TV Cable type ROG Audio, Video & TV 3 05-07-2007 09:06 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
