Old 06-22-2017, 10:17 PM   #1
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
What is this wire?
Found live 12V deep pink or red wire and white wire in the space below the closet in my 2017 22FB. Live even when the store switch is in off position. Any ideas? Thanks!
Llittle54 is offline   Reply With Quote
Old 06-22-2017, 10:25 PM   #2
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Should be power for the LP detector that is mounted on one of the doors opening to the space under the closet.
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 06-22-2017, 10:25 PM   #3
It's live all the time.
- Brad
Old 06-22-2017, 10:43 PM   #4
Llittle54's Avatar
2016 16' Sport
Sorry, I didn't mention they were not going anywhere. Just lying there live with crimp couplers on the free ends.
Old 06-23-2017, 11:00 AM   #5
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Are you the original owner? Some owners rewire the LP detector so it is switched and therefore is not a load when the use/store switch is in the "store" position. That extends battery life when in storage, although at the loss of an LP leak warning. If your trailer was previously owned, it may have been retired. To know if that's the case, 1. find your LP detector, 2. If it has a light on it (mine does... it's green) when the use/store is in the "use" setting, switch to "store" then wait a while and see if the light goes out 3. If not light in "use" mode, you'll need to remove the detector and use a multimeter to see if the power to the detector is switched by the use/store switch.
GammaDog is offline   Reply With Quote
Old 06-23-2017, 11:15 AM   #6
Retired.
. , At Large
I'm pretty sure that's the pre-wire for the solar.
Old 06-24-2017, 09:27 AM   #7
Llittle54's Avatar
2016 16' Sport
The mystery deepens... yep I'm the original owner and LP works but I'll double click later. Solar is yellow and green. Already positively identified the solar.
Old 06-24-2017, 06:13 PM   #8
2007 22' International CCD
Do you have a subwoofer? Mine is mounted in the bottom of the closet...
Grasping at straws here...
Old 06-24-2017, 06:36 PM   #9
Llittle54's Avatar
2016 16' Sport
No sub (doesn't come with a 22 sport) also why would it always be hot? Thanks though.
Old 06-25-2017, 09:37 AM   #10
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
on my 23D, I had s et like that in the back of my refridge compartment. In contacting AS they said it was the fridge power??? my fridge worked okay, and received power from another source. They had no answer, and said each was built custom.
My point is, what else is in that area that could be powered (maybe LP), and perhaps they did what they did in mine, and used another source. I isolated each wore with electrical tape to prevent and future shorting....
Troutboy
Troutboy is offline   Reply With Quote
Old 06-25-2017, 12:20 PM   #11
Llittle54's Avatar
2016 16' Sport
Love the each one is custom built comment. "Just hook up whatever wire ya want guys, it'll be fine."
Eventually I'm going to utilize the Weboost 22v power plug to these always hot wires and place a switch.
Old 06-14-2018, 02:55 PM   #12
2017 16' Sport
Orlando , Florida
same here in my SPort 16 closet... Found live 12V deep dark pink wire and white wire in the space below the closet . Any ideas? Thanks
mysparky14 is offline   Reply With Quote
Old 06-14-2018, 02:57 PM   #13
2017 16' Sport
Orlando , Florida
did you solve the mystery? I have the same in my SPort 16 2017
Old 06-14-2018, 03:05 PM   #14
For some reason, if you have an AS that includes a subwoofer, it's wired to be ON all the time.
Not saying it makes sense, but that's the way they build them...adding a switch to that circuit is on my list--since we never listen to the Sony radio anyway...
Old 04-08-2023, 06:15 AM   #15
2011 16' Sport
Springboro , Ohio
Loose pink (red) and white
Resurrecting an old thread here. Confirming this loose pair of wires behind the closet in my 2011 16’ sport are the same ones others are seeing.
Coming out of the wiring harness behind the sink.
They are power for the non-installed subwoofer?
I was thinking about adding a usb charging outlet and if this is constant 12v, this could work nicely.
(Also I thought I accidentally cut something and was searching everywhere for the other side if the wire. Kinda dicey AS leaving loose power around)
beckspeed is offline   Reply With Quote
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 06:09 AM
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
