Originally Posted by rmichaud6489
I own a 19 ft Flying Cloud. I am hooked up to city water and yet my water holding tank is filling up. This is the first time this has happened. Have I opened or closed a peacock valve I should t have? I have 2 valves under the dinette and 2 valves in storage compartment in back. What am I missing?
I have had a similar problem with our Sport 22FB. Per the advice of Boxite here on the forum, my problem was solved by doing the following:
1. Turn off the city water.
2. Turn on pump, have water in the onboard tank.
3. Turn on an interior faucet, sink, shower, whatever full blast. Flush toilet.
4. Shut off. Repeat a couple of times.
5. Turn off pump.
6. Turn on city water.
7. Check to see if problem is resolved.
Apparently the pump has some kind of one way check valve that can stick open, piece of crud, lime, whatever. Doing the above dislodges the junk and allows the valve to close. This now keeps the city water from flowing backwards through the pump and overfilling the fresh water tank.
