Old 05-27-2013, 01:41 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Want to upgrade tires on 2013 Bambi 19'..Suggestions
I'd like to put this question to the Bambi owners who have upgraded from the OEM Goodyear Marathons to a more "reliable" tire.
What 15 inch tire was your upgrade choice?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 05-27-2013, 02:08 PM   #2
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
I removed my Marathons for 15" Michelin MX series, installed Dill pressure monitors, and drive now with confidence.
mstephens is offline   Reply With Quote
Old 05-27-2013, 02:10 PM   #3
2000 30' Excella
Toledo , Ohio
Tires
You should look in the tires page there will be many opinions on tires most are going to 16" LT tires . Les Grace wbcci #14183
woodfox45 is offline   Reply With Quote
Old 05-27-2013, 02:54 PM   #4
I know that there is a lot of discussion on this topic but most relates to double axel trailers.
I still like to hear from people who have Bambi 19s.
Old 05-27-2013, 03:02 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You are carrying more weight per tire than any double axle Airstream. It may be a close fit, but I think a 16" Michelin upgrade would be an excellent idea.
doug k
Old 05-27-2013, 03:14 PM   #6
doug k
It looks like the oem Marathons are rated 2150 lbs. at 50psi and Airstream wants them at 65psi......hmmm!
The Bambi's GVWR is 4500.
The Michelin LT 225/75R16 are load range E and rated at 2680lbs and a max of 80psi.
What wheels have people bought to accommodate the 16s on the Bambi 19?
What tire pressure? Still go with 65psi?
Old 05-28-2013, 02:26 PM   #7
I'm seriously looking at upgrading to Maxxis M8008 ST 15 inch Radials on my 2013 Intl. 19. The Maxxis seem to be a more robust tire than the Goodyear Marathons and have a very high rating on RV and trailer forums.
My tire dealer recommends I go with the 225/75R15, 10 ply, 2830 pound load, 80 psi model. He also stocks the 8 ply, 2540 pound 65 psi model. The GYMs are 5/6 ply, 2540, 65 psi.
My only question at this point is whether the OEM Airstream wheels will handle 80 psi. Is there a way to check on this?
Old 05-28-2013, 02:33 PM   #8
Coloradobus's Avatar
Interstateflyer. If you pull one of your trailer's wheels and turn it over on the back side of rim should be a stamped capacity for what the rim can carry. As long as the weight rating if more than the tire you looking at your fine.
JIM n CHRIS
"62 ATW Overlander, '51 Flying Cloud
'67 GT, '90 Squarestream 29ft, 06 Bambi, Bigfoot slide in/GMC Denali K2500, Marathon Coach, Class A.
Coloradobus is offline   Reply With Quote
Old 05-28-2013, 02:46 PM   #9
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Installed 16' wheels and Michelin's LTXMN /S LT R16 E rated.. Including Spare. Had to bend spare tire holder arms so it would fit. Discount Tire. Wheels were Sendel T03BM.
Did July 2011 and still look new. Just did 123333 mile/ 5 month . No problem. There great.
knunut is offline   Reply With Quote
Old 05-28-2013, 02:55 PM   #10
knunut's Avatar
2007 20' Safari
Had Michelin's installed. July 2011. 16" LTXMN/S LT.225/75 R16 Load E.
Just came came from a 5 month 12,333 mile trip no problem . still look new.
Wheels are Sendel TO3 BM. Had to bend spare tire carrier arms out to fit new size.
There great !!!!
Heard good things about Maxxis.
Old 05-28-2013, 03:13 PM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have towed many miles with the Goodyear Marathons. Will be changing to Michelins. The best trailer should have the best tire. Some Airstreams on the dealer lot had Michelins. Mine did not.
Old 05-29-2013, 02:40 PM   #12
Hi Coloradobus...Couldn't find and markings on the back of my unit's wheels.
Do you know if there is another method of determining maximum inflation and load for these wheels?
My intention is not to increase the weight capacity of the trailer but instead run more durable Load Range E, 10 ply Maxxis STs at their rated 80 pounds.
Old 05-29-2013, 03:35 PM   #13
lewster's Avatar
Naples, FL , Hood River, OR
One of the first mods that I did to my then new '06 19CCD Bambi was the wheel/tire upgrade. From past experience, I have no faith in ST tires and wanted them removed from the Bambi post haste!
I went with a 6 spoke design from Trailer Tires and Wheels - trailer tires, boat trailer tires, trailer wheels, boat trailer wheels, aluminum trailer wheels and mounted a pair of 225/75-16 LRE Michelin XPS Rib tires. They were the same size that my Sprinter was running at the time, and the same tire! Never had an issue with any of the 6 Michelins while towing over 45K miles in 5 years.
You might have to remove the tire from the rim to get to view the load rating of the rims, as sometimes they are stamped on the inside of the wheel.
Old 05-29-2013, 04:01 PM   #14
K.C. , Missouri
I have seen a few Airstreams with this sendel wheel. Does this help you ?
T03SM | Sendel Wheels
gmw photos is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 02:30 PM
Converter upgrade suggestions? ('92 25' Excella) Doug C Batteries, Univolts, Converters & Inverters 35 08-07-2013 06:56 AM
CB Radio issues & upgrade - suggestions? ddgall Land Yacht/Legacy Motorhomes 5 02-12-2011 09:42 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 08:54 PM
Why not upgrade the tires on my Bambi? robert claus Tires 7 04-30-2008 06:01 AM
