Old 09-09-2019, 11:05 PM   #21
2019 22' Sport
Malibu , California
Thatís a great plan, thanks
Garfish is offline   Reply With Quote
Old 09-10-2019, 12:16 AM   #22
2019 22' Sport
Tabernash , Colorado
I am just a bit confused. I am in the process of installing the 712 and I have factory solar. Do I need to be concerned about the factory solar or do I simply connect the shunt to the negative coming in from the battery and then from the other end of the shunt to the bus bar?
Will the accurately measure the net charging?
JeffCross is offline   Reply With Quote
Old 09-10-2019, 06:14 PM   #23
2019 22' Sport
Malibu , California
I believe factory solar connects to buss bar not battery, yes? To get correct measurements all neg connections must be on load side of shunt so that means on buss bar. One neg to shunt from battery and one connection to buss bar from load side of shunt
I am installing roof solar and Victron MPPT controller will connect to buss bar so 712 will measure all
Old 09-10-2019, 06:45 PM   #24
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
The discussion we were having was about the RJ12 wire to connect the Victron shunt to the victron monitor. The Airstream pre-wire and connectors for that is 8-strand/8-pin RJ45. The Victron uses 6-strand/6-pin RJ12 (which is the cable they provide). To use the Airstream prewire, you need to change the RJ45 connector to an RJ12 Connector on both ends, at the shunt, and at the monitor. Using adapters, like Garfield is going too try (if they work), or doing what I described to use the connectors on the cable that Victron provided.
As for your shunt and factory solar, the solar should not impact your shunt installation. The negative solar controller wire can stay on the negative bus (likely that's where it is) and the shunt just needs to interrupt your negative battery cable as you described. If you have factory inverter, that one of course needs to be interupted by the shunt as well.
pcskier is offline   Reply With Quote
Old 09-10-2019, 07:48 PM   #25
waninae39's Avatar
2017 22' Sport
NCR , Ontario
@pcskier
to clarify the solar +ve and -ve leads both go into a solar controller.
The output of the solar contractile has the -ve going to ground.
it is NOT connected to the solar panel -ve
if the solar controler -ve lead goes to the shunt side with all the other loads, then the shunt can include/see solar power.
if it goes to the battery -ve then the shunt will not see any solar power
waninae39 is offline   Reply With Quote
Old 09-10-2019, 07:57 PM   #26
pcskier's Avatar
Park City , Utah
Correct. The neg output from the controller needs to be on the load side of the shunt...so it can go their directly, or it can go to the neg bus if it's already there, since there is then a jumper from the neg bus to the load side of the shunt. I'm presuming that factory solar puts the neg controller wire on the bus. That might not be correct though.
Victron BMV-712 Install Question Rounder44 Electrical - Systems, Generators, Batteries & Solar 25 11-23-2018 05:53 PM
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 03:21 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 07:53 PM
Victron 712 install in 27' FB Philip Jones Batteries, Univolts, Converters & Inverters 22 03-18-2018 03:20 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
