Old 11-20-2014, 12:09 PM   #1
Unexpected water in heater and battery drain on 19 ft. Serenity AS?
I left the sprinkler on it was hitting the side of the AS before I caught it. The heater is a Hydro Flame furnace by Atwood. I am sure that some water must have gone in the heater exhaust vent on the side of the AS. I can't detect any water even when I slipped a soft string down the out side vent and there does not seem to be any water on the inside. I have not turned it on yet and not sure if I should? Also my batteries seem to drain when the switch is in the power off position. I would appreciate any help. BillbB bbtyrec@cox.net
BillbB is offline   Reply With Quote
Old 11-20-2014, 12:27 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I doubt that a little water getting into the combustion-air plumbing of the furnace is a big deal, it likely gets condensation in there regularly when a cool night leads into a warm day, for example.
As to the battery drain even when the switch is in the "Store" condition, the LP detector always gets power and will eventually drain the battery. You can take the cable off the negative post of a battery (or install a physical disconnect switch near there) to really disconnect the batteries.
— David
Old 11-20-2014, 12:33 PM   #3
1981 31' Excella II
New Market , Alabama
Turn it on to bake the water out of it.
Perry
Old 11-20-2014, 01:15 PM   #4
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Perry
Agree that Perry's idea is sound. Be good to dry it out just in case.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Expect the unexpected... CampUnger General Interior Topics 2 05-07-2012 09:45 PM
Unexpected Danger on the Road overlander64 On The Road... 23 07-09-2011 09:16 PM
We're back - unexpected forums outage Janet H Forum Admin, News and Member Account Info 44 11-22-2009 09:56 PM
Unexpected opportunity? Hawkeye5 All Argosy Trailers 17 04-06-2008 07:55 PM
AIR is back from unexpected holiday break! Janet H Forum Admin, News and Member Account Info 11 12-26-2007 08:18 PM
