Old 04-16-2014, 08:25 AM   #1
2007 19' Bambi
Yorktown , Virginia
TV upgrade
We've got a 2007 19' Bambi, with originally installed non digital Sony TV.
It hadn't been too much of an issue as we don't use the TV much anyways and when we do it is in a campground with cable.
Last week while camping at WDW, I noticed that we could only get about 5-10 of the available channels even after reprogramming/re channelization. Some channels were video only, no audio.
So I guess it's time to upgrade the TV. The floor plans for new 19' Flying Clouds are identical to our Bambi and the images/brochures show the same TV mounting point above the refrigerator, so AS must have updated the TV but kept the same location.
Question 1: any older Bambi owners updated the old Sony TV but kept the same mount/location successfully? What model and size TV did you use?
Question 2: can any new 19' Flying Cloud owners list the model and size of the TVs in their units? Brochures advertise a 22" LED HDTV. I'd like to see if I can get something that matches a factory install.
randf is offline   Reply With Quote
Old 04-16-2014, 08:55 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I don't think a new television will solve the problem.
We have similar issues with a 2013 Classic with Samsung TV's.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-16-2014, 09:56 AM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
The TV mounts are pretty universal and there are adapters available, if needed. You might want to look at the Jensen TV's as they are made for RV's and are 110/12 volt so you can use while boondocking.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-16-2014, 10:36 AM   #4
aftermath's Avatar
Spokane , Washington
Sorry but I do not have a Bambi but I did change out my original Sony which was non digital for a Visio. I have had zero problems with it in the 5 years I have had it. I got one the same overall size and it was a simple mount and forget experience. I get very good reception on it and, depending on where I am, get HD quality picture from the antenna.
I looked into the Jensen but it was considerably more expensive. I have a converter in my 25FB and so when I want to watch the TV I simply plug it into the provided outlet next to the TV. I don't watch much TV at all so it is not a big deal to have the 12 volt capability out of the box.
I picked mine up from COSTCO at a decent price.
aftermath is offline   Reply With Quote
Old 04-16-2014, 01:11 PM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
TV upgrade
I'm in agreement here. There are a couple of things to check 1st...
Is the switch turned on to provide DC power to the amp in the antenna?
Get your ladder out to get access to the coax connection on the antenna head. Inspect the cable. Does the exposed sections appear cracked or badly weathered? Remove the connector from the head. Was it secure? Does it look corroded? If you have a volt meter or test light, verify there is 12V at the end of the coax with the switch on, don't short the center lead to the outer ring. Some installers put a rubber boot over the connector to keep out rain. I like dielectric grease.
Useful digital TV signals generally don't propagate as far as the analog signals they replaced so reception issues are common as one adds distance from the transmitters. The nature of digital transmission is you either get excellent reception or nothing useful. There's no in between.
Most TV antennas are directional; they work best when aimed towards the transmitter. Here's the Catch-22: For a channel scan to be successful, the antenna needs to be pointed first. In unfamiliar territory it is hard to know the correct direction to aim without an app on a smartphone or other means to determine where the transmitters are. Many campgrounds give you a map of the campsites at check-in that lists the local channels, but I've not yet seen one that has an arrow on the map pointing towards the transmitters. Your fellow campers may have done most of the work for you so by looking at where theirs are pointed, you should take their lead and start there. There are pointing meters on the market that can assist by showing signal strength as the antenna is rotated, point the antenna where the signal appears strongest, then run the scan. This can sometimes be trial and error. If you're in luck, all the desired channels will be in a cluster in one direction from you. Sometimes they might be at right angles from your location so in those cases you may have to settle for watching only some or repositioning the antenna as you change channels. It all depends on how close and strong the transmitters are and any physical obstructions such as hills or big trees that may degrade your reception.
On your Sony and many other brands, there is a menu option that displays signal strength for a given channel. By using it you can fine tune the antenna's direction for the best position if your video pixelates or freezes. Sometimes satisfactory reception is not possible short of relocating to higher ground.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 04-16-2014, 01:18 PM   #6
Lost in America
mojo's Avatar
Oak Creek , Arizona
The OP has a non-digital TV. They will not receive any digital signal without a converter box, hence his desire to upgrade. Had to do the same.
2017
Old 04-16-2014, 01:31 PM   #7
2008 27' Classic FB
Burkburnett , Texas
I assumed the op was using a converter box as the channel scan was mentioned. A TV with a builtin digital tuner can simplify things with fewer connections, but the bottom line is receiving digital TV in rural areas is not as easy as it was with analog transmissions.
AIR 47751
Old 04-17-2014, 06:07 AM   #8
2007 19' Bambi
Yorktown , Virginia
Thanks for all the tips.
We can't use the TV on this Bambi unless we're plugged into shore power, so a DC option isn't all that important. When we're at places that don't have utilities, it is usually a place where we wouldn't want to be watching TV anyways.
The TV is definitely a non-digital tuner type. I remember the RV store we purchased it from advising us to get one of the subsidized digital converters shortly after we picked up the Bambi. Since TV wasn't a high priority, I never bothered.
Now we are experiencing poor channel selection when at campgrounds that provide full hookups. The channel scan I mentioned was the built-in function of the TV itself. Whenever we get to a new campground, I use the channel scan function to tune to the local cable provider. That used to be enough to get all listed channels at a particular park, but we noticed last week at WDW that of the 40-50 channels (including the 5 or so WDW info-channels) we only picked up a handful and non of the info-channels. I figured that it was due to the age and specs of the older non-digital tuner TV.
Old 04-17-2014, 08:07 AM   #9
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
There are a number of LED 12vdc TV's out there. Some come with an attached power supply that converts 120vac to 12vdc. I bought a 24" LED VIZIO with integral DVD player from Walmart for less than $150. I cut off the convertor and attached a cigar lighter plug which works perfectly in the 12vdc socket nearby so I don't need to run the generator when boondocking. This has been working great for several year now. This unit looks exactly like the Jenson that RV suppliers get $350 for.
Ahab is offline   Reply With Quote
Old 04-17-2014, 08:27 AM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If you are interested, I have an extra converter NIB that you can have for the postage.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-17-2014, 06:35 PM   #11
2014 25' Flying Cloud
Anna , Texas
Flat panel TVs and monitors generally adhere to a standard called VESA, which specifies the threading of the bolts used to mount the monitor and the spacing of the mount holes. TV's in the 22" range most likely would be MIS-D which has four holes in a square pattern either 75mm or 100mm apart. Below is a picture of the back of the dinette TV from our 2014 FC 25.
There is a plate that mounts to the back of the TV via the 100mm VESA mount points. The pegs on the back of the plate then fit into slots in the mount attached to the wall. If your TV is on swivel arms, it may mount directly to the arms without an adapter plate.
This is a Samsung UN29F4000AF 29" diagonal, so it is a bit larger than the one you are replacing...check the spacing of the holes on yours to see which size your mount is designed for. You should be able to find a TV with mount points to match. Your mount may also support more than one size...note in the picture the mount plate on mine has holes for 75x75mm and 200x100mm.
kcollins is offline   Reply With Quote
Old 04-27-2014, 01:12 AM   #12
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
I changed my 75th Bambi to a Samsung 32" LED that uses a minimum of power and actually weighs LESS than the original 19" Sony LCD. It is a 2011 model Samsung in their "Touch of Color" design which used a molded crystal plastic bezel; the newer ones are made MUCH cheaper and aren't nearly as sturdy for RV use; the newer smaller Samsungs literally snap together.
The new TV fits the space perfectly and with a tightening and adjustment of the supposed "non-adjustable" mount, it doesn't move. I mounted small handles on the back of the TV to use as tie-downs as I use small straps to hold it snug against the wall; I don't have pictures of that. It works; doesn't wobble or move whatsoever. My straps are probably overkill but the original TV broke loose on the mount before the trailer was ever sold beating the hell out of the wood behind it; Airstream replaced the wood under warranty and installed the newer style mount. I re-mounted the mount straight and installed the Samsung 32". No problems at all.
One neat thing is that the mount swings out FAR. I can actually swing the TV out the door! I should get a pic of that...
ID:	210676   Click image for larger version
ID:	210678   Click image for larger version
ggoat!!! is offline   Reply With Quote
Old 05-10-2014, 01:40 PM   #13
2007 19' Bambi
Yorktown , Virginia
TV upgrade
Al
If the converter is still available I'll take you up on your offer! I think fitting a new TV in the same spot as the original will have to wait until the fall.
Old 05-10-2014, 08:58 PM   #14
Sure, I'm not using it. Bad news is it runs from AC, not 12 volts. I didn't think about that. If you are still interested, send me your address.
Al
S/OS #004
Axle upgrade markdoane Axles 12 04-14-2004 06:42 PM
Fuel Injection Upgrade? Buck58 General Motorhome Topics 10 11-19-2003 04:47 PM
Amarillo Upgrade Package joshua32064 2003 Safari 5 09-28-2003 08:14 AM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 08:19 AM
Rear bed frame upgrade ViewRVs Airstream Motorhome Forums 3 05-10-2003 09:53 PM
