Old 08-10-2017, 05:55 PM   #1
Sheridan , California
TV Audio
I know this has been discussed before but can't find the topic. Is there a way to route the dvd audio through the TV instead of the dvd speakers while watching a movie? The TV is over the bed while the speakers are on the other end of the trailer. If the fan or AC is on, it's impossible to hear the speakers.
Airabel is offline   Reply With Quote
Old 08-10-2017, 06:41 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Sure it's possible. How you do it depends a lot on which of the many disk players and televisions you happen to have. There might be combos that simply can't do it. My guess is that they would be pretty old at this point. One way to help with this sort of confusion over equipment would be to change your user info to list the year and model of AS you own. In most cases it's a dig into the menu on the TV sort of thing (internal speakers vs external).
Old 08-10-2017, 07:33 PM   #3
Our Airstream is a new 2017 16' Sport. The dvd player is a JVC and the TV is an LG. The front of the JVC opens up like a cabinet door to access the dvd player. I can't find anything in the manuals where the TV speaker can be selected over the remote speakers.
Old 08-10-2017, 09:05 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Isn't the DVD player connected to the TV by HDMI? HDMI carries audio and video. What are you using to control the volume? If you are using the JVC remote, try the LG remote. Where does the sound come from when you watch off-air TV? How do you control the volume then?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-10-2017, 10:00 PM   #5
2017 16' Sport
Cambridge , Massachusetts
I'm having the same problem with the same equipment, I have yet to find the menu setting to get the audio to play through the tv via HDMI.
jamesonb is offline   Reply With Quote
Old 08-11-2017, 05:10 AM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
not possible
though the TV is HDMI, the rcvr is NOT
there is an up-converter in the back of the rcvr , just video is sent in low resolution to the TV.
we replaced the TV and got one with a built in DVD and Audio out.
Now we cam play the TV /DVD audio over the overhead speakers or the TV speakers
waninae39 is offline   Reply With Quote
Old 08-11-2017, 05:54 AM   #7
2017 16' Sport
abita springs , Louisiana
After several trips was annoyed that while sleeping on sofa I had to listen to whatever was being played on DVD and sent to tv in bed area. Finally a nerd friend figured out how to solve my problem. No it wasn't ear plugs. On radio adjust fader 100 % to rear then turn up radio sound 100%. Then adjust tv sound as needed. It's not very loud but it works. Voila. Problem solved.
jsabatier is offline   Reply With Quote
Old 08-11-2017, 06:41 AM   #8
I didn't understand that the JVC receiver was also the DVD player. I have a single satellite receiver in the living area. I got a modulator which takes composite video (yellow jack) and stereo audio (red and white jacks) and puts it on a TV channel of your choice. I wire it into the trailer with a combiner at the satellite jumper. Presto, low resolution video and stereo audio at the back TV (and front, for that matter, but I run an HDMI cable to the front TV). I used UHF, but one of the older Channel 3/4 modulators might be even better as those channels are no longer used.
Here's one:
https://www.radioshack.com/products/...k-rf-modulator
eBay is full of them.
If you don't have the single cable TV/satellite wire and the satellite jumper wire like my trailer it would be a relatively simple project to wire one in, depending on where everything is located. You would want to put it near the switchplate that selects between antenna and cable.
Al
S/OS #004
Old 08-11-2017, 07:50 AM   #9
A few questions:
What is the model number of your JVC receiver?
Do you have the "upconverter" referred to above? What is it's manufacturer and model number?
Where is it located with respect to the antenna/cable switch plate?
Do you have the satellite/cable jumper plate? The parts manual seems to indicate tht you do.
If you have the jumper plate, is it near the JVC receiver?
Sorry for the "20 questions" but I'm not familiar with your trailer and I think there is probably a plug and play solution to your problem.
Al
S/OS #004
Old 08-12-2017, 06:55 AM   #10
2017 16' Sport
Originally Posted by waninae39 View Post
not possible
This is what I was afraid of. What TV did you get as a replacement?
Old 08-12-2017, 08:09 AM   #11
So I did what jsabatier suggested and got the same results. If I adjust the fader all to rear speakers and turn up the volume, sound comes out of the TV. That means audio is getting to the TV somehow.
The problem is, who wants to keep the reciever volume all the way up and forget about it, late at night.
Old 09-05-2017, 07:33 PM   #12
New York , New York
We're having the same problem with our 2017 16' Sport. Let us know if you have a good solution outside of getting a new TV or the fadar solve
righttoroam is offline   Reply With Quote
Troubleshooting car audio system wiring? davida Audio, Video & TV 3 10-25-2006 09:13 AM
AS speaker audio from LCD wheel interested Audio, Video & TV 22 06-10-2006 06:46 AM
Externial Audio Input thru Stock Stereo? Bambi_Bandit Audio, Video & TV 7 07-17-2005 10:37 AM
Safari Audio/Video Options TheLuvShack 2005 Safari 3 11-10-2004 05:02 PM
Repairing The Audio System Rodger with a D Audio, Video & TV 1 07-20-2004 10:11 AM
