Old 11-21-2017, 10:49 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Truma mover system
has anyone seen this from truma?
https://www.truma.com/int/en/product...html#radius=de
can this be added to a sport 22FB?
it would solve our parking issue.
i do not know what it costs
waninae39 is offline   Reply With Quote
Old 11-22-2017, 08:51 AM   #2
Msherw's Avatar
2018 22' Sport
Blue Sky Ranch , Texas
This reminds me of the Ford pickup trailer backup control system that reverse steers your rig into a tight spot. It may be nice if I didn't have a spotter and a backup camera, but otherwise it is just something else to go wrong. Also requires a hitch wheel which I distrust.
This might work for some folks (the video shows an unlikely use for it) but my thought has always been, if I can't maneuver my rig using the TV, spotter, and camera, I should just leave it in the barn at home. IMHO.
Good luck on this one...I keep seeing the name as 'Trauma Mover' not Truma. LOL
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
Ham Radio Call sign K5FT
WBCCI #18673 - of Texas group
Msherw is offline   Reply With Quote
Old 11-30-2017, 11:26 PM   #3
Boxite's Avatar
2008 22' Sport
It might be very helpful to place in a storage space but I'd be hesitant to use it as the video demonstrates. For one thing, the tongue jack wheel is too small for the terrain they try to portray. That little wheel will get stuck crossing that soft ground and stream. (Notice they didn't show the entire sequence?)
And once you get that trailer stuck in some tight space somewhere such as they try to show you..... (or if it breaks down once there)....how are you going to get your tow vehicle there, hitched up to get it pulled back out?
No, I'd not trust it to get into a camping spot but it might be a great system at a storage lot or tight storage situation.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 12-01-2017, 01:52 AM   #4
Long Island , New York
Gulp!
Direct link to video:
https://youtu.be/TNVIhnjBSaQ
Looks like a European/Canadian product, very expensive to retrofit to an existing AS, and ditto I would never use it as pictured in the video.
Gulp!
Old 12-02-2017, 04:12 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
can you buy this item in USA or CAN
i cant find a dealer for CAN or USA for this item
Old 12-02-2017, 06:07 PM   #6
2014 27' FB Eddie Bauer
Coldwater , Ontario
Hey Walter, they talked about this system on the fit RV YouTube channel when they toured Truma factory in Europe. Itís Europe only at this time.
bbandeddie is offline   Reply With Quote
Old 12-02-2017, 06:24 PM   #7
2002 19' Bambi
Lafayette , California
That was a European trailer and nearly all have very little tongue weight. Those little wheels are on most European trailers and are often used for maneuvering by hand.
Truma is a very well-known and respected company within the RV community in Europe. I doubt if they would market something that does not do pretty much what they claim.
Is it suitable for North American trailers? Probably not because that little wheel certainly would not handle our tongue weights.
Tim
Tim A. is offline   Reply With Quote
Old 12-03-2017, 07:02 AM   #8
waninae39's Avatar
2017 22' Sport
NCR , Ontario
IMHO
it is very easy to add a 1000 lb (capacity) shop wheel under the jack post.
if the jack post base plate does not swivel, then a flat bearing could be sandwiched between the wheel and the base.
it could be held on with the cabinet hand screw or toggle clamps.
now i just need to find a CAN/USA dealer to but the system from
Old 12-03-2017, 07:17 AM   #9
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
IMHO
Check with Can-Am RV. I saw a trailer (not an AS) at their shop with a similar system about 18 months ago.
Ray B.
ďOne test is worth a thousand 'expert' opinionsĒ
Sign at Boeing headquarters, posted by test pilot Alvin ďTexĒ Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 12-03-2017, 08:13 AM   #10
UncleBad's Avatar
2018 27' Tommy Bahama
Oro Valley , Arizona
truma mover system
Here is another similar option, which supports single or dual axel trailers:
http://www.purplelineusa.com/product...iler-mover.php
They also recommend and sell a heavy duty dual caster wheel for the tongue jack post.
I do not own one yet, but will need a system like this to store our future trailer at home.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 12-03-2017, 09:18 AM   #11
waninae39's Avatar
2017 22' Sport
NCR , Ontario
here is the install video
https://youtu.be/yjplJD2PKvc
the ego mover is U$1500
the ego dual caster is u$45
Old 12-03-2017, 10:34 AM   #12
The prices don't include labor, so that should be taken into account. Also, what would Airstream have to say about drilling into the frame, in terms of the warranty?
With an Airstream's frame being buried above the bottom skin, not sure how easy this installation would be IMO. Also, when replacing the bottom skin, it will have to be modified to miss the hanging parts of the Truma assembly. Are we sure that the entire new assembly will not conflict with [be in the same plane as] the bottom skin?
Possibly not so simple IMO!
Peter
Old 12-03-2017, 11:20 AM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
good points
ill call can-am next week and ask about both truma and purple line
Old 12-03-2017, 11:25 AM   #14
UncleBad's Avatar
truma mover system
For what itís worth, PurpleLine told me that for a 27FB I would need their eGo200, 4-motor system, which costs about $3,500 plus a new beefy caster wheel and install.
Old 12-03-2017, 02:34 PM   #15
For use on a reasonably flat surface, why not just go with a traditional hitch/trailer dolly?
https://www.google.com/search?q=trai...=airforums.com
https://www.google.com/search?q=hitc...=airforums.com
http://www.airforums.com/forums/f238...ly-171711.html
http://www.airforums.com/forums/f138...ns-172745.html
http://www.airforums.com/forums/f238...ly-145095.html
http://www.airforums.com/forums/f142...ly-160605.html
Old 12-03-2017, 02:39 PM   #16
Just wondering what is unusual about your parking situation, to require the complicated Truma system with drive wheels on the Airstream's tires?
What pitch or angle of rise is your driveway? Some of the more expensive traditional dollies come with hand-held remote controls which can apply the trailer's brakes, as I understand it.
How about a hitch ball mounted on the front of your tow vehicle, for tight parking situations?
Peter
good points
Old 12-03-2017, 02:40 PM   #17
Same question, could you describe your parking situation which requires the Truma's drive wheels to engage on the Airstream's tires? Is there a major slope to deal with?
Have you considered having a hitch ball mounted on the front of your tow vehicle for maneuvering?
Peter
Originally Posted by UncleBad View Post
For what it’s worth, PurpleLine told me that for a 27FB I would need their eGo200, 4-motor system, which costs about $3,500 plus a new beefy caster wheel and install.
Old 12-06-2017, 07:43 AM   #18
UncleBad's Avatar
Peter
Slope and slight turn in driveway with a tight 90 degree turn into RV garage. Had I built the house, there would have been more room to back up. Previous owner built RV garage for use with small utility trailer.
A trailer mover with remote is a perfect solution for me.
Old 12-06-2017, 10:03 AM   #19
But at $4,000 +/- plus labor, plus modifications to the AS, is the Truma worth the cost? Seems like a fancy more traditional dolly with braking ability might do the job IMO. [See Posts #12/15/16.]
Please let us know what your research continues to show.
Peter
PS -- What is the slope of your driveway? How about a front-mounted hitch on your TV?
Old 12-07-2017, 07:43 AM   #20
UncleBad's Avatar
I would not go with the Truma, but the PurpleLine eGo200. I considered a dolly and since I might also need the ability to move the trailer other places would not want to travel with it. I also do not want a front mounted hitch. A trailer mounted motor system with a remote control will work perfect for me.
Truma AquaGo tankless water heater waninae39 Water Heaters, Filters & Pumps 41 05-06-2019 08:00 AM
Truma WH owners, worth it? lsbrodsky Water Heaters, Filters & Pumps 20 01-12-2018 10:56 PM
Max incoming psi for Truma Combi water heater Bborzell Base Camp 3 06-09-2017 10:16 AM
Truma Info? DSM2570 Modifications 2 01-15-2016 03:17 PM
Instead of a Generator, Truma launches VeGA nmayer1 Electrical - Systems, Generators, Batteries & Solar 2 11-15-2012 08:54 AM
