Old 01-10-2019, 05:20 PM   #29
Pearl , Alaska
Originally Posted by RogK View Post
I'm looking at the Trailer Valet for a 2019 Sport 22 FB. It doesn't look like there is room to put a bracket on for the Trailer Valet TV5X (211), which would be nice to aid in quick hitching to a vehicle. It sounds like some have been able to attach it to the Sport 16, but it isn't clear to me how this was done. Should I still consider the Trailer Valet TV5X or consider the Trailer Valet XL instead?
I have the Trailer Valet XL for my Bambi Sport 16 2019...
Use to steer into my barn...during bad weather events...
Easily stored in my TV ...
For the amount of use it gets, I’m happy I went with this setup over the frame mounted version ...also the straight on approach from the ball hitch makes directing the RV easy for me...
Good Luck...!
Deltaboy59 is offline   Reply With Quote
Old 01-11-2019, 09:02 PM   #30
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we bought the trailer valet first. it is OK
BUT it is very limited in terms of the ability to steer the trailer. as it is attached on on one side of the frame, you can turn the trailer one way far more than the other directions. also the frame of the valet hits the trailer frame, thus you get less than 90 degrees of movement
we have a curved driveway and it was almost impossible to move the trailer where we wanted it to be
we now use the parkit360. https://parkit360.ca/
it give us total control and we can turn the trailer 270 degrees vs less than 90 degrees with the trailer valet
you can even take the trailer lift shoe off and insert the post into the parkit 360 socket and now you have total mobility.
we power it off the inside trailer battery
you can see the now unused trailer valet on the side
ID:	331498   Click image for larger version
waninae39 is offline   Reply With Quote
Old 03-28-2019, 09:40 PM   #31
Bruce
varicorp's Avatar
2017 16' Sport
Yorba Linda , California
Trailer Valet 16' Bambi Sport
I have a very 'tight' space next to my garage to park my 16' Sport. I measured this space carefully before I purchased the Airstream. I did not have the ability to back it in with my TV and after research I decided on the Trailer Valet. I was pleasantly surprised how convenient and precise I was able to put my Airstream in this space. I was very nervous at first, but the "slow and easy" approach with many checks, if you do not have a spotter, slipped it right into place with no problems. If I have to move a longer distance, I use my DeWalt battery drill motor with the adapter provided. This approach saves your back as you have to be bent over when cranking by hand. I am not sure why some people posting are talking about using it on one side of their frame. I set mine up with a "ball" that fits directly into the receiver. No problem steering at all. I can turn mine around on the center axis of the axle if needed. I bought mine from etrailer.com. Also, make sure you get the upgraded version with solid tires, not the intertube tires that were originally used. I am very satisfied with the quality and utility of this device.
Name:	Bambi parked.jpg
ID:	336812   Click image for larger version
Name:	Trailer Valet.jpeg
varicorp is offline   Reply With Quote
Old 03-29-2019, 07:49 AM   #32
UncleBad's Avatar
2019 16' Sport
Oro Valley , Arizona
Impressive fit! Are you able to get in the trailer while it is parked?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 03-29-2019, 12:26 PM   #33
Bruce
varicorp's Avatar
2017 16' Sport
Airstream door access when parked
UncleBad,
Unfortunately I am not able to access my 16' Bambi when parked along side of my garage. The good news is that I don't have to pay storage for a place where I can access the door when parked!
Old 03-29-2019, 12:33 PM   #34
Ayr , Ontario
Originally Posted by varicorp View Post
UncleBad,
Just add a door at the side of your garage to match the AS door. Problem solved.
gator.bigfoot is offline   Reply With Quote
Old 03-29-2019, 02:01 PM   #35
2019 27' Globetrotter
Salem , Oregon
If you need to move your 27 ft Airstream up a 15% grade. Here you go. DaveClick image for larger version
ID:	336857Click image for larger version
NoResults is offline   Reply With Quote
Old 03-29-2019, 05:15 PM   #36
UncleBad's Avatar
2019 16' Sport
Trailer Valet on Bambi Sport
UncleBad,
You must be much more patient than I am!
We are lucky and are able to store at home and have access. Not paying for storage sure is great!
Old 03-29-2019, 06:52 PM   #37
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we had one and stopped using it
not enough angular range
we now Parkit 360
power from AS battery
even move the as up a small hill
200 degree movement on our AS
ID:	336883   Click image for larger version
Old 03-30-2019, 07:25 AM   #38
UncleBad's Avatar
2019 16' Sport
Do you make use of the 7-way connector going up your hill for trailer brake control? I noticed it isn’t plugged in.
Old 03-30-2019, 10:19 AM   #39
waninae39's Avatar
2017 22' Sport
NCR , Ontario
yes
i use the 7 pin to control the brakes. it will release the brake and when power goes on, it puts as brakes back on , when you stop moving
very nice feature
Old 03-30-2019, 10:22 AM   #40
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I have had two Trailer Valets and they both worked flawlessly. I am getting older and decided to invest in a mover with a motor. Otherwise, I would have kept using the Trailer Valet....it's affordable, easy to use and does what it say it will do.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-04-2019, 09:37 AM   #41
2019 16' Sport
New york , New York
Good Luck...!
I wanted to get the XL instead of the 5x so I wouldn’t need the bracket but was told by trailer valet the 16’ sport did not have enough tongue weight for the XL.
Seems to be working for you.Have you noticed any issues related to this?
Dmaloney13 is offline   Reply With Quote
Old 05-04-2019, 07:57 AM   #42
UncleBad's Avatar
2019 16' Sport
Originally Posted by waninae39 View Post
yes
very nice feature
I also noticed that you use the jack pole instead of the hitch ball for your connection.
I would like to try that as well but I am afraid that the jack pole will bend under the stress? I do have a few inclines and undulations I have to navigate.
Also given that you’re using the jack how do you lift the trailer onto the mover?
Sorry in advance for stupid, possibly redundant or previously asked questions!
Bambi Sport/Bambi Safari TerryReeves Airstream Classifieds 0 10-19-2014 12:49 PM
2013/2014 Bambi Sport 16' Sport Wrap Windows in back? maureencrist 2005 and newer - Bambi all models 7 04-21-2014 08:46 PM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
Airstream Sport 22 :: 2011 Airstream Sport Lone Eagle0 Airstream Registry Discussions 0 08-19-2011 08:32 AM
2010 Airstream 16' Sport Bambi Lightweight Trailer eBay Watch Airstreams on eBay 0 11-06-2010 01:30 PM
