Old 07-04-2016, 06:11 AM   #15
Nowhere , Somewhere
Brakes are required by law on any AS.
avionstream is offline   Reply With Quote
Old 07-04-2016, 07:03 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Please post links to this law.
Old 07-04-2016, 07:06 AM   #17
Nowhere , Somewhere
Scant do links but it's easy to look up. Just google trailer brake law.
Old 07-04-2016, 07:09 AM   #18
Nowhere , Somewhere
Every state I saw listed required trailer brakes above 3000 pounds.
Old 07-13-2016, 03:28 PM   #19
2016 16' Sport
Longwood , Florida
Name:	ImageUploadedByAirstream Forums1468445177.370836.jpg
ID:	266716we finally brought the Sport 16 home yesterday. We have the Fastway weight distribution hitch and a Prodigy wireless brake controller. Easy tow on the two-hour trip home. It handled great!Click image for larger version
Name:	ImageUploadedByAirstream Forums1468445284.555310.jpg
ID:	266717Click image for larger version
Name:	ImageUploadedByAirstream Forums1468445300.783992.jpg
fdelle is offline   Reply With Quote
Old 07-13-2016, 03:39 PM   #20
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I could be wrong and the angle of the photo could be deceptive, but the front end of your trailer appears to be a little high, and the shank/WD (that which goes into the receiver of the Jeep's hitch) appears to be at the lowest point the dealer could go to.
Now I wouldn't insinuate the possibility the dealer didn't install the proper shank, but it's something you should be aware of.
I know from personal experience, achieving a level configuration of trailer to vehicle will make a huge difference in road/highway performance.
A simple check would be to take the Jeep and trailer to a known level location and measure the height of the front and back of the trailer from the lower rub rail.
Good Luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 07-13-2016, 05:24 PM   #21
Adventure.AS's Avatar
2017 25' International
Port Dover , Ontario
Nice Looking Rig
Originally Posted by fdelle View Post
Attachment 266716we finally brought the Sport 16 home yesterday. We have the Fastway weight distribution hitch and a Prodigy wireless brake controller. Easy tow on the two-hour trip home. It handled great!Attachment 266717Attachment 266718
I'm sure you won't even know it is behind you. Just be sure the trailer is level when hitched up.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 07-13-2016, 05:53 PM   #22
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
Jeep
Excellent rig setup! We just got a new Rubicon. The seats are so nice ! We have a 1998 TJ with a straight six, and it runs like a champ! No way were getting rid of that bad boy. We had to get a new wrangler cause we love the old one so much.
The frame is rusting on our TJ , but I am looking for a welder on Craigslist and soon will be cutting, fixing and adding steel. Heavy Duty.
This New wrangler is so much larger. ( seems to us)
Keep us posted on pulling the AS with your Jeep. That is an excellent setup.
I kinda doubt we'll be pulling our 28' with our Jeep.
Have a good one,
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 07-20-2016, 05:39 PM   #23
2016 16' Sport
Longwood , Florida
Towing Sport 16 With A Wrangler
Name:	ImageUploadedByAirstream Forums1469057864.274367.jpg
ID:	267388Our first trip has been a blast. Four-hour drive to Tallahassee. No problems towing. Jeep gas mileage went from 21 highway to 13.5 towing the Sport 16.
Old 09-30-2016, 03:41 PM   #24
Robert
randbeth's Avatar
2015 16' Sport
Pineville , Louisiana
fdelle, My wife and I are new at this and to AS forum. We have nearly the same situation. 16' Bambi and Jeep Willy's Unlimited. Did lots of reading prior to buying because we really did not want to change our tow vehicle. Looked to be near the limit for the jeep but decided to give it a try. WDH and electronic brakes both installed at AS dealership. Left for home in Huston traffic at 6PM. Crazy, but was amazed at how well the AS towed behind the Jeep. So smooth and had a little power left over at 60 mph. Made the 5 hr drive home without any problems. Towed like a dream. Coolant remained at normal levels.
Also, much like your experience, when I disconnected the Trailer from the Jeep the next day the Jeep Tail lights would not go out. Only way to get them off was to disconnect the battery. Took to Jeep dealership and was easily fixed.
We have gone out once so far and loved it. There is a learning curve, however and my wife and I are still figuring out how everything works. But we pulled there and home just fine.
randbeth is offline   Reply With Quote
Old 10-06-2016, 06:25 PM   #25
Tyvekcat's Avatar
Jeep`
Yeah, I think I'm going to have to start looking for a small AS. Those look great behind the wrangler, looks like an excellent combo
Safe travels
Old 10-06-2016, 06:49 PM   #26
Jeep Wrangler Unlimited + AS Sport 22
We have had a great time towing our Sort 22FB with iurcWrangker. Can-Am in London ON customized our factory hitch to make it stronger and able to stand up to the torque created by the weight distribution hitch. I have taken my rig over a CT weigh scale and the hitch is doing a great job of moving the weight from the rear axle to the steering axle.
The identical Jeep in Europe has a tow rating of over 7,000 lbs.
Ray B.
WBCCI #6497
Old 10-06-2016, 08:07 PM   #27
N/A , N/A
Originally Posted by Adventure.AS View Post
...The identical Jeep in Europe has a tow rating of over 7,000 lbs.
Just curious, do you have a link to the specs for this 7000# tow rated Wrangler? Thanks.
rostam is offline   Reply With Quote
Old 10-06-2016, 08:41 PM   #28
Seattle , USA
I'm surprised Andy at Can-Am let that hitch setup out like that.
The Jeep is definitely squatting in the rear a goodly amount while the trailer seems a bit high in the front.
Seeing numerous examples of Andy's expertise in the past, this surprises me...especially the spring bars being so un-parallel to the A-frame.
Andy's the MASTER of setups. He could keep a Geo Metro from squatting in the rear while hitched to a 34 footer.
Something just seems off here...that's alot of rear-end sag for a Can-Am setup.
RareStream is offline   Reply With Quote
Tow Vehicle - Jeep Wrangler to tow sport 16 iamcrazy Tow Vehicles 22 04-10-2016 07:37 PM
New 2015 16' Sport, towed by Jeep Wrangler Unlimited jt1911man 2005 and newer - Bambi all models 28 05-05-2015 05:53 AM
Towing with a Jeep Wrangler Jeeper Tow Vehicles 17 05-22-2008 10:20 PM
