Old 10-21-2014, 09:37 AM   #29
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Say if I bought a rear view camera, I don't need side mirror extension any more?
Any rear view camera you suggest? So you have a separate LCD to mount on the dash for the camera, right?
Side view mirrors just don't accomplish what you want to see and that's vehicles in the blind spot just behind your trailer. Furthermore, the ones that do enable you to see close behind stick out so far that going through toll booths are a danger to the money collectors.
If you have an iPhone 5 or 6, check out the one Wayne&Sam refers to in his post at rvrearviewcamera.com. There you can see a youtube video of the camera system in actual use.
Fred
acstokes is offline   Reply With Quote
Old 10-21-2014, 11:56 AM   #30
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
No, I would always also have proper towing side mirrors.
The voyager system is excellent, I have a wireless display in the car that I just remove when I'm not using it.
Installed:
I use a an iOauto (magnetic) holder on a car specific double device ProClip mount to hold the display and my phone.
Kind of like this, but double mount bracket (not my car/picture).
Not my picture, but IOauto looks like this:
Fred
Interesting idea but I wouldn't want my phone dedicated to a task like that while I'm driving. It would also get quite hot if the display was running constantly for 4-5+ hour drives.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 10-21-2014, 12:03 PM   #31
acstokes's Avatar
2009 30' Classic
I've driven 7-8 hours without it over heating. Also, it's not dedicated as you can still receive and place calls and messages.
Fred
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
Old 10-21-2014, 12:28 PM   #32
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Towing mirror: can see following cars directly behind the trailor?
Fred
Yes, I understand that, but then you lose access to the camera view if you (or likely your passenger) would want to use something that requires the screen. If you purposely don't use it (so as to not lose camera view), or end-up using another device (for the same reason) it's essentially dedicated.
Great, that it's working for you but I've used phone based cameras before and flip-flopping between functions isn't ideal for my wants/needs....especially for an important task like this.
Multifunctional devices have their place but so do dedicated devices.
'15 Classic
Instagram: cory_can
Old 10-21-2014, 12:39 PM   #33
acstokes's Avatar
2009 30' Classic
So for the duration of the call or message you lose the view you never had to begin with.
Fred Stokes
WBCCI #2810
Old 10-21-2014, 11:25 PM   #34
2007 19' Safari SE
Los Gatos , California
Towing mirrors
I'm towing a 19' Bambi with a Toyota Tacoma and bought a French brand of side mirror extensions. When driving down a totally straight road I can see enough to know if someone is behind me. If I want to double check, a very slight weave in my own lane is enough to get a better look at what's behind me. I can't imagine the need for a camera while towing.
Rye
RyeL is offline   Reply With Quote
Old 10-22-2014, 03:08 AM   #35
Baltimore , Maryland
knowing if someone is behind you is so simple; put on your turn signal and suddenly they will come out from behind you before you can change lanes.
Old 10-22-2014, 06:29 AM   #36
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Rye, with a narrower/shorter trailer such as your Bambi the blind spot is significantly smaller (convergence angle) and you probably wouldn't need it. Strap an extra ~8ft and the additional width of the wide bodies and you'll probably feel differently. My previous trailer was similarly sized to your 19 Bambi so I have a good sense of the difference.
Frank, predicting someone else's movements based on my actions doesn't sound very reliable to me.
All, if some of you want to use Yoda mind tricks or your Aunt Sally's soup recipe to see in your rear blind spot...all the power to you. For me, a rear camera works very well and gives me additional information. IMO, more road awareness is safer and other than the insignificant cost there is no downside to having the extra visibility.
'15 Classic
Instagram: cory_can
Old 10-22-2014, 06:36 AM   #37
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by slowmover View Post
I cannot tell you the number of times I have come up behind a combined RV rig on the Interstate, pulled out seven lengths back to pass, and found the driver surprised as I come up. I drive an average of 10-12k miles monthly.
How do you know they are surprised?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-22-2014, 07:05 AM   #38
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
The size of mirror glass is central. Tall for the rear view and BIG convex for what is next to you. I drive 12k miles monthly in almost every conceivable condition. MyTV/TT is longer than that tractor-trailer but the mirror size discrepancy seems to be more about cosmetics than function. I changed my factory towing mirrors to a larger head replacement and will be adding BIG convex.
The "best" mirrors I have seen that should be on our vehicles are those on UHaul box vans or like the VELVAC 714579. Use these as reference. Tall and flat for distance and a quite large convex (6-8") for traffic next to you as guideline
12,000 miles, monthly ?
OMG
"Common Sense is like Common Courtesy,
ain't neither one too common these days"
Dobber is offline   Reply With Quote
Old 10-22-2014, 10:38 AM   #39
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
By their reaction
Old 10-23-2014, 09:27 AM   #40
2013 25' FB Flying Cloud
Mountain Top , Pennsylvania
This is my 1st trailer, and I have no experience in towing before.
Recently I bought a towing mirror: Amazon.com: Fit System 3891 Deluxe Universal Clip-on Trailer Towing Mirror: Automotive, I was expecting to use it to see the cars behind my 16' bambi.
However, I'm not sure if it's my bambi too "fat" then my TV(durango), or technically this kind if mirror doesn't feature the ability to cover the directly behind area. I basically can't see nothing of my own line behind my trailer.
Any suggestion on the towing mirrors to let me see what's going on behind me?
Invest in a rear camera system (camera on back of trailer; view screen on windshield) and dispence with the extension mirrors.
jgdunham is offline   Reply With Quote
Old 10-23-2014, 10:47 AM   #41
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A camera is no substitute for proper mirrors. Cite a study which shows the eye makes no differentiation between the very different views. There are differences and those matter. The eye/brain is going to process those differently.
A camera, rearward and forward, is good for proving fault for an accident if it can record. It may be a help in backing. But it is no substitute for proper mirrors.
Except when backing what is directly behind one has only relative importance. Using mirrors properly is more important. Set an audible timer to go off every 15-secs and see how many hours you can tolerate it. Or, every time you stop for any reason, clean those mirrors and glass. No such thing as "clean" after about a hundred miles. (Side glass& mirrors trump windshield handily for importance).
Old 10-24-2014, 06:48 AM   #42
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
You are about 5 years behind the times. The auto makers are already lobbying to allow cameras to eliminate mirrors because they work better. Case in point, all upper end Honda Accords have a right side camera which displays on dash when right turn signal engaged or a button on the end of the turn signal stalk is pressed. It shows you twice as much as any side view mirror and even has markers so you know when you are too close to those newfanggled bike lanes. They use some sort of Flir I am guessing because they work fantastic in low light/no light. Never mind that almost everyone uses backup cameras now as standard on cars. After driving with these for a year and not needing to turn your head half as far, I can attest to the fact they are FAR superior to mirrors. I have no idea what "eye/brain" stuff you are talking about. A mirror is about as anti eye/brain as you can get. Try to do anything using a mirror in regular life...not that a rear facing camera is any better at that, but certainly no worse.
renderit is offline   Reply With Quote
Can I hookup my Sleep Number bed directly to the DC power bank? jasperkins Electrical - Systems, Generators, Batteries & Solar 6 10-04-2013 03:51 AM
Mirror, mirror off the wall! Pudentane General Repair Forum 2 08-09-2009 07:28 PM
See the Trailor Jump..... Jim Jarzabek Off Topic Forum 9 01-29-2006 02:59 PM
Mirror Mirror on the wall early General Interior Topics 2 11-20-2005 09:13 PM
Mirror Mirror on the wall.... GT1963 The Pet Forum 9 03-15-2004 08:42 AM
