Originally Posted by JJTX
Yes, it's normal. Remember, when the fridge is on gas, theres a pilot light and then a flame when the system calls for heat, so the heat you feel is normal.
It maybe normal in the sport 16 but it is definitely not the way it should be. The hot counter top means that hot air that should be exhausted is getting trapped in dead space leading to a much less efficient fridge.
Do what Wanna? did and add a baffle on top. You can seal up the sides around the fridge with some aluminum duct tape.
I did the same and the counter was never the slightest bit warm again.
I’d send pictures but I no longer have the sport.
