Old 08-04-2017, 06:27 PM   #1
2019 22' Sport
Malibu , California
Tire PSI newbie question
2017 16' sport has Goodyear ST 215 R75 14s and says on tire max PSI 65. Owners manual says inflate to 50 and from the dealer it is 60, cold. If loaded about 3200 then what should PSI be?
Garfish is offline   Reply With Quote
Old 08-07-2017, 02:12 PM   #2
Boxite's Avatar
2008 22' Sport
The label on the side of the tire is informing at what weight the tire will support it's maximum load. The owner's manual is making a recommendation based upon the mfr's knowledge of the trailer and it's capacity.
The tire pressure at which the dealer placed the tire could be the result of the dealer making an error, having a poorly-calibrated gauge, or deliberately overfilling the tire to avoid having to make daily checks (knowing that 60 psi will not damage the tire per the sidewall label.)
Follow the owners manual, IMO.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Maximum PSI and Tire size Jase Tires 27 05-01-2017 12:12 PM
Tire Psi Butch McNabb Tires 19 12-07-2016 10:04 AM
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
