Old 10-11-2018, 07:13 PM   #15
Bend , Oregon
In the end I used the spare in the rotation during the change. Wanted to go through the exercise of removing it since I hadn’t done it in awhile and inspect the spare. There isn’t must clearance under a Sport 22! Used the mounting plate to jack the trailer with another jack stand ‘just in case’ under the ‘jack’ location. Everything went fine.
chaeha is offline   Reply With Quote
Old 10-31-2018, 02:21 PM   #16
Johnnyooo's Avatar
2016 16' Sport
Colrain , Massachusetts
Use two jack stands and the front jack.. that's all there is to it..
Johnnyooo is offline   Reply With Quote
Old 10-31-2018, 06:57 PM   #17
2002 19' Bambi
Lafayette , California
Unless you live in earthquake country and are as paranoid as I am.
Tim
Tim A. is offline   Reply With Quote
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Does anyone have any tips on removing silicone? Petethefeet Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-06-2006 06:40 PM
need to replace both front stabilizer jacks charlie tuna Jacks, Stabilizers, Lifting and Leveling 12 08-23-2006 06:55 AM
