Old 05-05-2006, 08:48 AM   #1
2005 16' International CCD
Joliet , Illinois
Thinking about the 2006 19' SE, Please Help?
My husband and I just looked at the 2006 19' SE. What is a good price for this Airstream? The MSRP they had was around 41000. What should I expect to pay? Would this airstream fit in a 2 car standerd garage? It would be nice if it would. What are your opinions on the 2006 19 SE? We wanted to see the 16 but the dealer in chicago area didn't have one. We will be going back today, I really want to inspect it ask any questions I need to. Can you please give me some things to look at, and questions to ask the dealer. I've been reading this forum and from what it sounds like I'm not making a bad decision looking at an airstream, so many happy airstreamers. Thanks for help you could give.
anussia is offline   Reply With Quote
Old 05-05-2006, 09:19 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Discounts vary from anywhere between 10 to 25% off of list price. The more popular the trailer, the less the discount. Don't pay a separate dealer prep charge. Good dealers don't add these miscellaneous charges on to the final negotiated price.
Most likely the trailer will not fit into your garage because it's too tall. Heck my van only clears my garage door opening by less than a half an inch.
If possible consider have a spare tire carrier and tire added to your new trailer. Two Fantastic Fans are better than the standard one.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-05-2006, 09:28 AM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Measure the garage - most garage doors are too low to accommodate a travel trailers height - even if the garage were long enough.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-05-2006, 10:12 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Standard garage won't fit an RV (non-popup).
The dealer in Giman isn't all that great (if that's the one you're talking about).
I was happy with our 19' Bambi for the two of us and a pooch, but it was a bit tight. Airstream has since come out with a 23' CCD that you could possibly purchase for the same retail money of a 19' CCD (18% off list of $51k). Don't get me wrong, the 19' is a nice unit as is the 16' and they both have a place, but now that the 23' is out, it weighs only about 1000lbs more than the 19', yet gives you 2 axles (better than a single axle--except on the tollways around here ), larger fridge, more storage, more windows and a larger fresh water tank.
You can take a peek at one here:
http://www.colonialairstream.com/newinventory/8079.html
It can also be purchased non SE/CCD which could lower the cost by about $5k.
Old 05-05-2006, 11:22 AM   #5
Joliet , Illinois
Thanks so much for all the help. There is a new Airstream dealer in bolingbrook. We will be going to milwakee today to check out their selection. They have a 16 and a few 19s. Wish me luck.
Old 05-05-2006, 03:07 PM   #6
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Some things to consider:
Bed width on the 19' is 48". Will that be wide enough?
Dinette sleeper width in case someone has to sleep there.
Counter top space in the galley for food prep.The 19' uses stove and sink covers.
Wet or dry bath. Some like the dry bath, but it uses valuable space. Wet baths are a little messy when wet, but are more space efficient. A big plus in a small trailer.
Single axle vs. double axle. Double axle trailers handle better. What will you be towing with? Determine if your tow vehicle will be able to manage your trailer adequately.
Consider your "rainy day" scenario and whether you and your family can enjoy the tight confines for a few rainy days, if need be.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 05-05-2006, 06:07 PM   #7
1963 19' Globetrotter
Moline , Illinois
Thumbs up Another dealer to shop
You might check with the dealer in Davenport Iowa- Adventure RV they seem to have really good selection of new Airstreams. I think they might be in Bolingbrook also.
I'm over in Davenport all the time with questions for the service department as well as buying various things. They have been very good to deal with . Don't know about the sales side but you might want to give them a call.
63air is offline   Reply With Quote
Old 05-09-2006, 10:58 AM   #8
Joliet , Illinois
The dealer in Davenport set up another branch in Bolingbrook. They have been open for 2 weeks.
Old 05-09-2006, 11:29 AM   #9
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
If I recall, My 05 Bambi is just under 10 ft. tall, and 8 ft. wide. I tow a 24 ft. Trade Wind, and a 19 ft. Bambi. The two axles on the Trade Wind are nice, in terms of safety during a tire blowout, but I can't say there's much of a difference in handling and towing between the two. If you have enough tow vehicle and buying power, you may want to take a good look at the 23 ft. If it had been available when I was looking, I would have seriously considered it. I didn't like the layout and the wet bath in the 22 ft., the 25 ft. was more than we need, and my tow vehicle would have been marginal.
Good luck.
SilverRanger is offline   Reply With Quote
Old 05-10-2006, 05:37 PM   #10
2006 19' Safari SE
San Diego (Carmel Valley/DelMar) , California
We just purchased the 19' Safari Bambi SE last week. We also looked at the 23' and 25'. The 23' has a sink that, to me, takes up a lot of space. Also, the table set up seems kind of cheesy, in my opinion. The 25' is a little too much for our Jeep Grand Cherokee. But that FB in the Special Edition is one fine trailer. Frankly, I am grossed out by wet baths, so the 16' Quicksilver was not going to work. We are a family of three, 2 adults and one son who is 11. Then we have our Golden Retriever. I realize that space might be a little tight, but my husband and son (and do) plan on camping in a tent at some destinations. Anyway, I love the Special Edition Safari Bambi so far. If we decide to trade up, I'm sure that we can sell it pretty easily as this is a popular model.
sunn is offline   Reply With Quote
Old 05-10-2006, 06:02 PM   #11
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Hi Sunn,
Welcome to the forum. I'm looking forward to hearing the experiences of another Bambi owner. It's only the two of us, but we seem to have plenty of room for our type of camping.
Old 05-10-2006, 07:11 PM   #12
LuminumTraila's Avatar
2006 19' Safari SE
NW of Boston , Massachusetts
We just brought home our new Bambi Safari SE last weekend and we dearly love it. We chose it over the 23' and the 16'. The 23' seemed like too much for family camping and we didn't want to tow that much, and the 16' seemed like not quite enough (tank capacities and floor space), although we were leaning toward the 16' for quite a while and really liked the layout with the bed in the back and the rear panoramic. We haven't camped yet in the Bambi but already it feels like it fits us like a glove. Our last trailer, a '76 Safari 23' did not feel as roomy as the Bambi, probably due to the layout. But with 2 adults and 2 children (age 8 and 4) we feel just right in the Bambi.
Good luck with your decision!
Doug & Jamie, AIR #650
LuminumTraila is offline   Reply With Quote
Old 05-11-2006, 09:41 AM   #13
spinyman's Avatar
2005 19' International CCD
VALLEY CENTER , California
19 A Wonderful Compromise
We recently purchased a 19 CCD model and love it.To us,it's called camping,not bringing your home with you.Also, the smaller trailer will fit in more places on the road than a larger one can.We originally fell in love with the 16 with the duel panoramic windows,but once we checked the specs,the 19 seemed much better equiped.Still think those little 16s are the coolest looking though.
spinyman is offline   Reply With Quote
Old 05-11-2006, 09:53 AM   #14
2006 19' Safari SE
spinyman - We totally agree with you. We also call it B&B for when we travel. Just a place to stay cozy and dry for the night, and eat meals as we go. Whenever I start looking for something we really need for the camper, I try to think of the most minimal, compact, lightweight solution that's possible. I like simple, and small.
Old 10-28-2006, 11:16 AM   #15
Roscinante's Avatar
2006 19' Safari
Suisun City , California
Motivation
One of the things that tipped us in the 19' Bambi's favor was the fact we are moving up from a T@B. That trailer took, literally, 15 minutes to hook up and once on site about that to set it up. It motivated us to get out and travel because it was so easy to just "grab and go."
The Bambi is a little more complicated and a WHOLE lot more comfortable. We did a lot of research, went to couple different dealers, and walked through eveything we could find (including Scamps, Nash, etc). The Airstream won us over. First, it reeks (in a good way) of quality. Second, the 19' has a huge amount of storage, and it since it is just my wife and I, we felt it was a much better fit for us than something longer, fancier, etc.
We love our trailer and have no "buyer's remorse" at all.
Jerry
Roscinante
Jerry and Avis
2006 Safari Bambi 19'
2005 Toyota Tacoma PU
"Mi Casa Es Su Casa!"
WBCCI #6716
AIR #17388
Roscinante is offline   Reply With Quote
Old 10-28-2006, 12:48 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Jerry, we camp with friends who have a pop-up camper. It takes them an hour to set up and break down. They shake their heads when I've used a battery powered hand drill and a sparkplug socket to put down our stabilizers, deploy the awning, and we are done. "Grab and go" is good!
5 meter Langford Nahanni
Old 10-29-2008, 01:45 PM   #17
2008 19' Bambi
Decatur , Alabama
I just bought a Bambi CCD too and love it. Selling my Casita now! This is the coolest TT in the world!!! Pricing...I got my 06 for 22K. Looks new.
Nightwind15 is offline   Reply With Quote
2006 bambi
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 11:02 AM
2006 International, considering but.. hesitant 63air WBCCI Rallies & Events 6 10-31-2005 07:14 AM
Thinking of Buying '72 Overlander Joe C 1970 - 1973 Overlander 16 07-20-2005 07:01 AM
gotair's painting dilemma got me thinking... summerkid Off Topic Forum 16 04-16-2004 01:17 AM
Thinking about Argosy 89350crew All Argosy Trailers 5 07-21-2003 09:17 PM
