Old 02-19-2009, 09:20 AM   #1
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
That 16' Bambi combo tank thing
A quick question: is the plumbing in a 16' Bambi set up so that you can divert gray water on its own into a portable tote tank, or are black and gray always mixed together?
Black water in a blue boy seems like a bad thing....
mutcth is offline   Reply With Quote
Old 02-19-2009, 09:26 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Nope. Both are in one tank. Taking out any fluid will without question include some black tank stuff, unless you have not used the head.
Old 02-19-2009, 09:56 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Are we talking 1960s or 2000s? The 60s models drain the gray water directly, the black is held separately.
Zep
Old 02-19-2009, 10:30 AM   #4
mutcth's Avatar
2007 23' Safari SE
2004 and up.
Old 02-19-2009, 11:02 AM   #5
soldiermedic's Avatar
Florissant , USA
It's a combo tank that everything goes into. Don't take too long a shower, or you may have to clean your feet again.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-19-2009, 01:09 PM   #6
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Maurice
Old 02-19-2009, 04:38 PM   #7
Head Animal Wrangler
BamCamper's Avatar
2010 19' International
Los Osos , California
Never had that problem.
Unless you're packing in lots of people
or boondocking for weeks you'll be fine.
Rally on,
Bam
and no, those photos are not me.
BamCamper is offline   Reply With Quote
Old 02-19-2009, 05:24 PM   #8
1972 Argosy 20
Tallahassee , Florida
I would like someone tell me how the kitchen sink and shower are routed to the black water tank. The 20' Argosy I purchased doesn't have a tank at all and the drain pipes from the kitchen sink have been cut. There is no sign of a shower. How does the kitchen sink and shower drain find way to the black tank which will be above the floor? Or is it located totally above floor?
Bo
Bo Walker is offline   Reply With Quote
Old 02-21-2009, 05:44 PM   #9
mutcth's Avatar
2007 23' Safari SE
Bo, your Argosy never had a gray water tank. (It was built in the years before they became available.) The water from the sink and shower just dump out onto the ground; they don't flow into the black water tank. The only thing that goes into your black water tank is toilet water.
That was OK when campgrounds didn't mind you dumping water on the ground - not so much anymore. You can put a portable "blue boy" tote tank that connects to the outlet and collects the water.
Old 02-21-2009, 07:19 PM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
Bo
mutcth -- I think you're closer to answering Bo's question than anybody else. Bo has asked this before. The top end '72 Excella 500 was the first with a grey tank. A few more '73s had them but they only became universal in 1974.
Does Bo or anybody with a transitional '72-73 have a manual? How about a scan of the page pertaining to the waste gate valves? Actual photos of the valve positions? Real life experiences?
Thanks!
5 meter Langford Nahanni
Old 02-22-2009, 07:35 AM   #11
1972 Argosy 20
Thanks for the information. Yes I have ask the question before. I think I ask for a lay out or routing of plumbing and electrical wiring. I got a drawing of electric from the forum but I can't tell much about it. I can't enlarge it enough to read it.
I thought I had read of someone running their gray water into the blank tank. But I don't know how they did it.
Also, I am not yet very good at finding what I need from the forum. As I plunder and blunder through it I think I'll get aquainted with it enough to better find what I'm looking for.
I much appreciate your response.
2007 bambi
16' CCD Owners: Combo tank remarks Hubba General Repair Forum 6 04-18-2009 08:11 PM
2005 Bambi 16' ericinrb 2005 and newer - Bambi all models 25 10-25-2006 06:54 PM
16' Ccd & 16' Bambi Ron Edwords Waste Systems, Tanks & Totes 2 03-26-2006 11:30 PM
Bambi or 16' CCD Shep Our Community 27 07-18-2003 08:51 PM
CCD Grey/Black Tank Combo LuvSub 2002 - 2005 International 5 05-11-2003 07:04 PM
