06-19-2018, 04:54 PM
2018 22' Sport
Blue Sky Ranch
Teak bath floor for Sport 22FB
Got our handmade teak floor for the main bath and the shower. Awesome addition that made our AS feel like a land yacht. When you arrive back home, simply lift the floor boards and sweep or mop to clean debris.
The company https://www.teakworks4u.com advertises 22 FB for shower or main bath but if you are buying for 22FB Sport, they now have our floor tracing. Be sure to specify SPORT. 22FB is too wide.
M!ke
2019 Tiffin Wayfarer 24TW
Ham Radio Call sign K5FT
06-19-2018, 05:50 PM
2011 22' Sport
Portland
, Oregon
That does look lovely and would help with getting dust/sand/rocks stuck to your feet when stepping out of the shower...I am guessing it was in the $160-ish range?
06-19-2018, 09:16 PM
2022 25' Flying Cloud
NCR
, Ontario
they want over$600 for the batch /shower set
ill make my own
just place packing paper on the floor and trace the outline
use any wood you have handy , like white oak, cherry, cedar and use strips of PT underneath
too clean the floor, just lift it out.
06-20-2018, 06:11 AM
2018 22' Sport
Blue Sky Ranch
They are expensive but the function served goes beyond esthetics. By having them in both shower and bath area, you never worry about slippage from water or an uncomfortable stone bruise from stray ones left on the floor.
Yes, they are pricey but my wife and I gave them to each other for Valentine’s Day. Since I really don’t have the tools to do this (my expertise is electrical and electronic engineering) the cost was something to be considered carefully.
M!ke
06-20-2018, 09:53 AM
2011 22' Sport
Portland
, Oregon
ill make my own
One option to look at is buying "deck tiles" and just cutting the to fit. Ikea, Home Depot and various other places offer these "floating" deck solutions that just click together...many have plastic backing, some have wood backing. Home Depot has ipe ones that are 2x2' for ~$37...should be pretty easy to use that as a starting point to DIY...though adding the cost of those and if your time is worth much it may close the $ gap with just buying them pretty quickly.
06-20-2018, 03:35 PM
2018 22' Sport
eden prairie
Mike, that really looks nice.
I know it's obvious to everyone but me, but what is "PT". I know it ain't "toilet paper" as that's backwards. I literally have every tool imaginable it's time I do a project like that.
2018 Sport 22fb
Ford Transit 250 Quigley 4x4
Gitchee Gumee on the Keweenaw Peninsula
06-20-2018, 04:13 PM
1982 28' Airstream 280
Port Angeles
I can't say for sure but my guess would be pressure treated to resist rot.
I would recommend using all teak. It is a very oily wood so it is very resistant to rot. More importantly it does not get slippery when wet, that is why it is used on boat decks.
Cheers, Dan
~ Margaret Thatcher ~
06-20-2018, 05:02 PM
2007 22' International CCD
Corona
I would NOT use any pressure treated lumber where humans go barefoot--it can be very toxic, and could also potentially stain the shower floor. Particularly the greenish stuff--it is made with CCA preservative, which is IIRC, Copper/Copper Arsenate! That stuff has been banned in California because of leaching and toxicity...
Stick with teak for all the wooden parts if you build one. Note that teak is notoriously difficult to glue because of its oily nature. Marine supply or Rockler woodworking (stores and online) should carry adhesives that work on the stuff...
It should slowly weather to a nice soft gray color if left alone.
If you want it to stay brown, marine supply places have oil-based finishes and treatments specifically for unfinished teak that will maintain the color without making it sticky or toxic, and will help it resist water even better...
The most beautiful deck grates for boats I've ever seen were from a small wooden boat shop in San Pedro, California years ago. They were interlocked teak strips custom milled on a special machine, assembled with half-lap joints and glue, and then edged with solid teak. Totally custom, and expensive as hell, but they were absolutely stunning...
06-20-2018, 05:57 PM
2006 19' Safari SE
Tucson
I believe he is referring to " Pressure Treated" wood ... the subsequence comment about PT wood having potentially toxic chemicals is something to consider. (It is also not recommended for campfires for the same reasons.)
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
06-21-2018, 07:37 AM
2018 22' Sport
eden prairie
I would probably try stainless pocket screw joinery along with some physical interlocking of some sort. Never worked with teak however. I have this motorized pocket hole machine that I have been using for interior framing believe it or not, works great in tight places or where you might have to move a stud later for rough-ins.
2018 Sport 22fb
06-21-2018, 07:40 AM
NCR
, Ontario
yes "Pressure Treated" wood underneath sitting in te water
i have IPE/iron wood at home- made the outside deck with it 20 years ago and its still standing fine.
yes to SS screws
