Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 2005 and newer - Bambi all models
Old 12-29-2017, 03:17 AM   #1
2018 26' Flying Cloud
Hot Springs , Arkansas
Tank heaters in 20' FC
If we have full hookups and low temps in the mid 20's can the tank heater pads be used without drawing down the battery? This is our first time to winter camp!!! The manual gives little information except for dry camping use!!! I think the heaters provide 7 degrees of heat below freezing.? May have heard that from Colonial Patrick on YouTube.
ljsigman is offline   Reply With Quote
Old 12-29-2017, 03:29 AM   #2
Mantua , Ohio
If the pads are twelve volt , then they will draw down your batteries if you do not have shore power. With shore power you should be okay that is their intended use.
Old 12-29-2017, 03:32 AM   #3
Even when hooked up to 30 app?
Old 12-29-2017, 03:51 AM   #4
2015 16' Sport
Lakeridge , Virginia
Yes. Everything except the AC and microwave runs of 12 volts DC. You have a converter charger which is a device that converts 110 Volt AC (household) power into 12 Volt DC (battery) power and simultaneously charges the RV batteries. As avionstream stated, the tank heater draws quite a bit of power but when you are hooked up, the power comes from the converter not the battery. If your not hooked up, the tank heater will drain your battery pretty quick.
Peanut is offline   Reply With Quote
Old 12-29-2017, 03:57 AM   #5
Thanks Peanut. I miss read Aviostreams post.
Old 12-29-2017, 09:34 AM   #6
CruizinDux's Avatar
Washington , Missouri
ljsigman, you should be fine if you're hooked up to SP. We recently camped in the low 20's and for the first time turned on the tank heaters. We had SP, did run the furnace opened the kit and lav cabinet doors to circulate some air and all was good. I did disconnect the CW connection and drained the hose and filter.
BTW you may want to check out http://www.airforums.com/forums/f542...27845-149.html which is a link for 20 footers. It contained a lot of inf specific to 20's
Happy Trails
CruizinDux is offline   Reply With Quote
Old 12-29-2017, 09:46 AM   #7
Bob, thanks so much!!!!
Old 12-29-2017, 12:25 PM   #8
2018 25' International
Sioux Falls , South Dakota
Cool Does a 2018 25' Signature have Tank Heating Pads?
DaytonaDan is offline   Reply With Quote
Old 12-29-2017, 06:08 PM   #9
2007 22' International CCD
Only if you find a switch for turning them on somewhere. Mine is near the tank
Level gauges
Old 12-30-2017, 08:48 AM   #10
The manual only speaking 20' and 23'RB as having tank heaters!
Old 12-30-2017, 04:43 PM   #11
2017 25' International
Framingham , Massachusetts
No it does not. Your furnace (not heat pump) warms the tanks and belly pan area. Only a few models have heat pads instead of the ducted furnace air for the tank warmth.
quietguy is offline   Reply With Quote
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
Tank heaters-forced air? Jfed Eddie Bauer - All Models 14 11-30-2013 09:57 AM
Holding tank heaters Judy Edwards Full-Timing, Winter Living & Workamping 2 11-08-2012 06:13 PM
Adding Tank Heaters fr8tshaker Fresh Water Systems 7 10-17-2008 07:15 AM
Tank Heaters -vs- Antifreeze TitusLivy Winter Living 21 09-10-2007 04:07 PM
