Old 09-04-2017, 03:34 PM   #1
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
storing a portable grey table container in am AS 22FB-solution found
many campgrounds do not have sewage at the site. our sport 22FB has a small grey tank. if we stay more than one day, we need to remove the grey tank contents to a sewage drop
if we take two showers and clean the dishes twice in one day, our grey tank is full. the black tank fill much slower
we disliked storing the grey container inside the trailer and moving it all the time.
well, i built a solution. It fits under the trailer on the right hand side and to the right of the sewage pipe holder, and to the left of the front right jack
here are pics of it under construction and before it gets installed.
I have to wait for the heavy rain to stop
pic #3 shows the road shield, it is on the side that faces the TV. this prevents all the crap, dirt mud etc form coating the side of the grey tank container.
This wall and the floor are made from sheet aluminum. The floor has 100,000 smalls holes for any moisture to drip down.
Once it dries up ill post installed pics
Name:	0 -base of portbale grey tank holder.jpg
ID:	294017   Click image for larger version
Name:	2- completed portable grey tank under trailer holder.jpg
Name:	3- completed portable grey tank right side with road shield.jpg
ID:	294019   Click image for larger version
Name:	1b-portable grey tank showing where it fits.JPG
waninae39 is offline   Reply With Quote
Old 09-13-2017, 06:46 PM   #2
2018 22' Sport
Nashua , New Hampshire
Looking forward to seeing the installed pics! Have you completed the project yet?
jamtek is offline   Reply With Quote
Old 09-15-2017, 09:34 AM   #3
Boxite's Avatar
2008 22' Sport
We dry camp for 5 days at a time with no problem re: size of water tanks.
A plastic bucket in the shower is used to catch water until the hot water reaches the shower-head. We then take a "navy" shower. (A navy shower means get wet, turn water off, lather up, turn water on and rinse off. Any soapy water that happens to land in the plastic bucket simply helps keep the toilet and black tank clean, because ....We use the bucket water to flush the toilet.
We use disposable plates for eating. They make good campfire kindling, or go into a strong, contractor-type trash bag for disposal.
We wash dishes/pots/pans with a large plastic bowl of soapy-water, then toss the water out in the woods. The bowl is then filled with fresh water to rinse the dishes. The rinse-water is added to the shower bucket.
Grey tank, black tank, and fresh tank lasts for almost a week before any needs to replenish occur.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-23-2017, 04:34 PM   #4
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
complete gray tank holder install -under as 22FB
i completed the install of my grey tank holder
under my as 22FB
i had to move the sewage hose holder to the left side of the fresh water tanks
the 3" lift kit is needed to ensure you have sufficient ground clearance
as mentioned in my first post, the right side has a full alum shield to stop road crap from hitting the tanks
under the grey tank is a mesh that allows water and dirt to fall onto the ground
Name:	10- gray tank holderunder as22FB with locks.jpg
ID:	295397   Click image for larger version
Name:	11- gray tank holder - left side.jpg
Name:	12-gray tank holder right side.jpg
Old 09-23-2017, 04:38 PM   #5
2007 27' International CCD FB
San Diego , California
Great job. It does look like it hangs rather low. How tall is the hold overall?
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is offline   Reply With Quote
Old 09-23-2017, 06:25 PM   #6
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
its now 4.5" above ground
before the lift the water tank was the lowest at 7.5"
thus i am 3" lower than when i got the trailer
i don't see an issue and will test it in a trip within weeks
Old 09-23-2017, 06:46 PM   #7
1979 23' Safari
Wayland , New York
Looks like a nice bit of work, hope it works out.
Key to clearance would be to keep it as close to the wheels as possible. It comes down to geometry. The fresh water tank can stick down farther because it's between the wheels so trailer pitch doesn't change the clearance much. When the clearance is farther forward and rearward you can get significant changes in clearance due to pitch change with the tow vehicle
Old 09-23-2017, 07:02 PM   #8
GMFL's Avatar
2014 23' International
Dadeville , Alabama
RR tracks going to tear that out from under your trailer and make a mess. It is right behind the spare tire holder a when the wheels of the TV are on one side of a hump and the trailer wheels on the other that's BAD news. And with only 4" of clearance it ain't going to take much. I could tell you how great it looks, (and it does look awesome) but want to be fair to you and say that ain't gonna work.
Old 09-23-2017, 07:54 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That looks dangerous close to the ground. Good luck.
MICHAEL
Old 09-23-2017, 08:05 PM   #10
2015 22' FB Sport
Savoy , Texas
I'm afraid that it won't work without a lot of lift. Our fb22 water tank without a lift gets within 3 inches quite often. Our blue tank goes into pickup bed. There's lots of clearance there.
SpinWhite is offline   Reply With Quote
Old 09-23-2017, 08:47 PM   #11
1979 23' Safari
Wayland , New York
One way to tell would be to raise the stabilizers and slowly retract the jack. If the carrier is going to hit before the jack is fully retracted you'll likely have issues.
Or run a string from where the tire meets the ground and the forward bottom of the jack. If it protrudes below that line you have potential issues.
Can you close up the gap on top?
Old 09-24-2017, 07:13 AM   #12
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
i will try the string method
there is not much gap atop as the grey tank has a hose connection that is proud of the grey tank
i don't think i can move it closer to the wheels
ill look again
Old 09-24-2017, 07:21 AM   #13
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
without the lift kit, the water tank had 8" of clearance, if you have places that leave only 3" left, then you dropped 5"
my grey tank holder has 4.5" of clearance, thus i cant drop as much.
maybe i can rebuild the base with .25" alum bar instead of 1" wood
that would give me the 5" cleance
Old 09-24-2017, 07:56 AM   #14
Adventure.AS's Avatar
2017 25' International
Port Dover , Ontario
... the grey tank has a hose connection that is proud of the grey tank
You could raise the base of the compartment if you could store the tank upside down with a corresponding slot in the base for the hose connection to go into when you slide in the container.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
22FB Bambi SPort into shipping container sltsmith Airstream Trailer Forums 5 01-17-2013 02:36 AM
Temp grey tank solution 1962 Globetrotter seawaatty 1960 - 1964 Globetrotter 0 05-10-2010 04:29 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Has anyone ever found a solution to this furnace problem? wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-07-2007 12:04 PM
