Old 04-16-2013, 04:25 PM   #1
Jack Dog in So Cal
2013 16' Sport
Orange , California
Stiff Locks
Has anyone had trouble locking and unlocking the rotating units on the access panel to the under bed storage at the back of their 16' Bambi's?
Mine are very hard to operate especially in cold weather. I've lubricated the locks and the left one is so stiff I'm afraid the key will break off in the lock.
Jack Dog
in So Cal
JackDog is offline   Reply With Quote
Old 04-16-2013, 04:42 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I imagine they are like on the other late model trailers. There is a steel swinging "arm" latch on the inside of the lock. Take it off and bend it ever so slightly, just enough to make it more movable, and put it back on. You could also add a little lube to it.
But be very careful it's not too loose as water could then blow past the door seal.
A way to check it the seal is tight enough is to turn on the light inside the compartment (or put a flashlight inside) at night when it is dark outside. Then look all around the seal for any light coming through a gap in the seal.
doug k
Old 04-16-2013, 05:23 PM   #3
1977 Argosy 24
Milltown , Wisconsin
Have you tried pushing in on the door when you turn the lock?
ventport is offline   Reply With Quote
Old 04-16-2013, 05:30 PM   #4
2010 27' FB Classic
N/A , Texas
Once you do all the adjustments spray some of this stuff in the key entry.
It works great.
