08-09-2016, 06:34 PM
2015 16' Sport
Upper Sandusky
, Ohio
Stabilizer Jack Crank Extensions Question
It is a hassle to raise and lower the stabilizer jacks on our '16 because it is low and the crank attachment is recessed. I noticed that on the big AS models the crank attachment point is at the outside edge of the trailer and easy to reach. Anyone added an extension to the jacks to move the attachment point out and if so, how? My back and knees thank you.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
08-09-2016, 06:42 PM
2012 25' Flying Cloud
Battle Lake
Take along a portable drill with a socket to fit the stabilizers (from Camping World among others) and it's a quick job lowering and raising the stabilizers. Remember these are not jacks on an Airstream, just snug down to stabilize the trailer.
Doug and Cheryl
08-09-2016, 06:49 PM
Walnut Creek
Saw a Bambie with electric stabilizer jacks at the dealer this week. There was one getting them installed and another had them. Seems to be a movement.
Cranking is good exercise. Cranking is good exercise. Cranking is good exercise. Cranking is good exercise.......if you say it..... Pat
08-09-2016, 06:51 PM
2016 25' Flying Cloud
Venice
I agree with above. I believe it's a 3/4 " drill bit. I got mine at Ace Hardware after explaining what I was trying to do. Take a picture of your stabilizer & show the hardware guy so he understands what your trying to do.
A portable drill with this attachment takes about 2 minutes to up or down all 4 stabilizers.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
08-09-2016, 06:53 PM
1974 27' Overlander
Baltimore
, Maryland
Is money an object? VTS sells complete BAL jacks with the longer shaft for $65 a pop... Don't know if that is any longer than what you have.
08-09-2016, 07:04 PM
2005 30' Classic
Burlington
, Ontario
Agree with the drill idea - and you could easily fir it wth a extension if you have to I sould think.
I have been doing that for years - presently use a 20V Dewalt, and the batteries also work on a powerful flashlight and a vacuum cleaner that I take along!
I also use the drill for running up the jack screws on our Henlsley hitch - and now and then for other chores - even drilling holes!!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
08-09-2016, 07:05 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
All Airstreams are not the equipped the same way
On the smaller/lesser quality Airstream trailers the stabilizers do not have a nut on the end so that a socket fits onto them. On my Safari it takes a round tube with a slot. The stabilizers on my Safari are almost useless, so wobbly I hardly ever use them. And, they are difficult to deploy since the end of the screw shaft is about 8-10" back from the edge of the trailer wall. And, the legs do not extend down enough, so that additional blocking is needed. These are not as sturdy as those on the other Airstream trailers I've owned.
Alan
08-09-2016, 07:15 PM
2005 30' Classic
Burlington
, Ontario
Interesting! It would be easy enough to have nuts welded on if you wanted I imagine, or make up a suitable cross-pin driver on an extenion to use in a drill.
Bran.
2005 Classic 30'
08-09-2016, 07:20 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
You are all correct, the drill would be very quick and easy. The PO issue and I have the same issue is that the stablizers are set so far back from edge of trailer. It really requires getting diwn low and under to crank or drill them down. Has anyone ever extended them to the edge on the 16 or 19, so a drill could be quickly used? I like idea of electric jacks.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
08-09-2016, 07:29 PM
2015 16' Sport
Upper Sandusky
, Ohio
We bought a slotted bit off Amazon that works with a drill. Problem is it still requires crawling on the ground to line it up on the attachment point. Also, clearance is tight on the right front one by the step. I thought about having a welding shop look at adding extensions though electric jacks sound like a really nice addition.
08-09-2016, 08:19 PM
1979 23' Safari
Wayland
, New York
Electric jacks, ugh, just another thing to break. Find a metal shop see if they can make you a handle or socket extension with a really long reach.
08-09-2016, 08:21 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
I used an electric drill on my previous T@B teardrop, but the ends of the jack screw was closer to the edge of the trailer body. I tried using it on the AS, but found it was quicker and easier with the manual crank. I have thought about cutting the crank off about 18" long so I could chuck it into the drill, but it would still be awkward. I'm also going to bring gardener knee pads to wear to add some cushioning while kneeling on the ground. A headlight is also needed in the dark.
Ray B.
08-09-2016, 08:36 PM
2012 25' FB Flying Cloud
Celina
, Ohio
On our 22 Sport I took the stabilizers off and had a local weld shop add 8 inches to the 'length.
08-09-2016, 09:26 PM
2016 22' Sport
2020 25' International
Clinton
, Land of Purple Mtn Majesty,Montana
It's a no brainier for me on my 22'FB. 12" extension,1/4 adapter for the drill, pcs of carpet pad to kneel on, 5/8" deep socket with a groove cut in it. For the time it took me to read these responses I could completed the task including putting the tool away.
Another option buy and extra crank,cut off a 14" section ,put in a drill and your set to go. Far cheaper than welding, extensions, buying jacks etc.
It doesn't need to be an issue..
08-09-2016, 09:32 PM
2015 16' Sport
Upper Sandusky
, Ohio
Found the longer crank BAL's (below). Supposedly they are used on non-Bambi Airstreams. Hopefully they would bolt on easily but at $250 a welder might be a better option.
http://airstreamsupply.com/Jacks-and...et-of-4-400093
08-09-2016, 09:37 PM
2015 16' Sport
Upper Sandusky
, Ohio
You are correct except for those of us with joint replacements and other physical problems making getting up and down from the ground painful. Same goes for the low sewer attachment, but that is another thread.
08-10-2016, 04:26 AM
2015 22' FB Sport
2018 27' Flying Cloud
2021 30RB Classic
Fredericksburg
Buy a second slotted hand crank and cut off the handle to create a new bit for your cordless drill. Buy a garden kneel pad. Tape a 1/4" square of some reflective tape on the end of the stabilizer rods to make it easy to find in low light situations.
08-10-2016, 07:29 AM
2016 22' Sport
Clinton
Your point is well taken...mid 70's myself, multiple back surgeries, but it goes with the territory. I'd rather face up to the task and " get to do it" than have to stay at home wishing I could.
08-10-2016, 07:40 AM
2005 30' Classic
Burlington
, Ontario
I suppose if you had extensions welded on to bring the end of the jack screws out to the edge of the trailer, you could then use a universal joint arrangement on a hand crank or drill so you would not need to be down on teh ground level with the jack screw.
Brian.
2005 Classic 30'
08-10-2016, 11:16 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
I wanted one. The wife said no, and not be lazy. So now I have my son doing the the stabilizer jacks!
