Old 08-09-2016, 09:32 PM   #15
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
Found the longer crank BAL's (below). Supposedly they are used on non-Bambi Airstreams. Hopefully they would bolt on easily but at $250 a welder might be a better option.
http://airstreamsupply.com/Jacks-and...et-of-4-400093
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Old 08-09-2016, 09:37 PM   #16
remphoto's Avatar
2015 16' Sport
Originally Posted by Rpatrick16 View Post
It's a no brainier for me on my 22'FB. 12" extension,1/4 adapter for the drill, pcs of carpet pad to kneel on, 5/8" deep socket with a groove cut in it. For the time it took me to read these responses I could completed the task including putting the tool away.
Another option buy and extra crank,cut off a 14" section ,put in a drill and your set to go. Far cheaper than welding, extensions, buying jacks etc.
It doesn't need to be an issue..
You are correct except for those of us with joint replacements and other physical problems making getting up and down from the ground painful. Same goes for the low sewer attachment, but that is another thread.
Old 08-10-2016, 04:26 AM   #17
twbucksr's Avatar
2015 22' FB Sport
Fredericksburg , Texas
Stabilizer Jack Crank Extensions Question
Buy a second slotted hand crank and cut off the handle to create a new bit for your cordless drill. Buy a garden kneel pad. Tape a 1/4" square of some reflective tape on the end of the stabilizer rods to make it easy to find in low light situations.
twbucksr is offline   Reply With Quote
Old 08-10-2016, 07:29 AM   #18
2016 22' Sport
Clinton , Montana
Your point is well taken...mid 70's myself, multiple back surgeries, but it goes with the territory. I'd rather face up to the task and " get to do it" than have to stay at home wishing I could.
Rpatrick16 is offline   Reply With Quote
Old 08-10-2016, 07:40 AM   #19
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We bought a slotted bit off Amazon that works with a drill. Problem is it still requires crawling on the ground to line it up on the attachment point. Also, clearance is tight on the right front one by the step. I thought about having a welding shop look at adding extensions though electric jacks sound like a really nice addition.
I suppose if you had extensions welded on to bring the end of the jack screws out to the edge of the trailer, you could then use a universal joint arrangement on a hand crank or drill so you would not need to be down on teh ground level with the jack screw.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-10-2016, 11:16 AM   #20
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
Originally Posted by PKI View Post
Saw a Bambie with electric stabilizer jacks at the dealer this week. There was one getting them installed and another had them. Seems to be a movement.
Cranking is good exercise. Cranking is good exercise. Cranking is good exercise. Cranking is good exercise.......if you say it..... Pat
I wanted one. The wife said no, and not be lazy. So now I have my son doing the the stabilizer jacks!
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-10-2016, 11:23 AM   #21
2006 19' Safari
East Greenbush , New York
I bought an extension with a chuck on the end. It's about a foot long. I put the slotted socket in the extensions chuck, and put the extension in the drills chuck. Works great on my Bambi. Its a Lisle part, 17450 - which Amazon says is currently unavailable - I bought it in 2012.
I've attached a picture...
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
heitkergm is offline   Reply With Quote
Old 08-10-2016, 11:30 AM   #22
Wingeezer's Avatar
2005 30' Classic
Wouldn't the drill do the same thing for a lot less $, plus be useful for other things?
I saw a video the other day advertising a 2017 Classic 30. That trailer seemed just loaded with electric gadgets, and I couldn't help thinking that just looked like trouble down the road!
Nice while they work, but a pain when they don't, and I have found on our trailers over the years that most of my problem areas have been electrical - usually corroded connectors, so for my part I would certainly prefer less, not more!
I'm sure many folk wouldn't agree though!
Brian.
2005 Classic 30'
Old 08-10-2016, 11:58 AM   #23
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I don't know why the stabilizers are set further in on the smaller trailers.
I first noticed this on a Bambi camped next to us in the Terraport at Jackson Center.
My opinion on raising and lowering with a drill:
It is easier to keep up with, store, and use the crank than to keep up with and store a drill, batteries, charger, and socket and to keep the batteries charged.
That all just seems like a big ole hassle to me.
Too much sugar for a dime-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-10-2016, 12:01 PM   #24
m.hony's Avatar
2013 30' Classic
I thought maybe the frame rails on the smaller trailers are closer together/further in as compared to the big trailers.
I am sure the smaller trailers are narrower, but I don't know how much narrower.
Are the little trailers 7' wide as compared to 8.5' wide for the big trailers?
That was the explanation I gave myself as to the difference in the stabilizers.
Mine on my 30' are right even with the outside of the trailer.
The little Bambi next to us at Jackson Center had the stabilizers so far in and under you had to get down on your knees and peer under the trailer to find them- annoying-
TAC #MS-10
Airforums #70955
Old 08-10-2016, 12:37 PM   #25
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
They are set back because the have a shorter screw shaft, not because of the frame rail. They are not the same stabilizer.
These are lighter duty like those on my Safari:
These are the heavier duty with the longer shaft that are on my Excella.
Alan
Old 08-10-2016, 12:38 PM   #26
Free bird's Avatar
2016 22' Sport
Grays , Illinois
I am disappointed in airstream.
I have the same issue with the bending over and kneeling. I had knee replacements which prevent me from doing this. Almost have to stand on my head to find the stabilizers. Feel like I am putting on a comedy show for what should be a simple task. Tried a stool and still cannot see. Usually end up laying in the stones, mud, etc. Then have to do fight to get up. Why does airstream make it so difficult? Thought I was buying quality. Big laugh.
Free bird is offline   Reply With Quote
Old 08-10-2016, 12:50 PM   #27
2011 30' Flying Cloud
Greenback , Tennessee
I can see how some people could have a hard time getting down there to crank the stabilizers, with or without a drill. Assuming you are traveling with a spouse or significant other, could you not ask your helpmate to do this one job involved in setting up? I know my wife would do it in a heartbeat, especially if I had a nice drill-with- extension setup. It might be worth a try.
By the way, I am 77 and have rods in my back, so I understand the problem.
Gneiss Guy is offline   Reply With Quote
Old 08-10-2016, 01:10 PM   #28
Nowhere , Somewhere
The po of my Avion put a small piece of electrical tape low on the trailer side where the stabilizers are. Still have to reach under, though.
avionstream is offline   Reply With Quote
2015 22Sport Stabilizer crank bar Tagsmom 2005 and newer - Bambi all models 9 02-01-2016 07:18 AM
Broken sleeve on stabilizer crank SSquared General Repair Forum 24 04-17-2015 08:44 PM
Mirror extensions recommendations Engie Towing, Tow Vehicles & Hitches 23 12-17-2012 04:11 AM
Tire Valve Extensions...Help and Advice jbsails Argosy Motorhomes 4 06-22-2009 05:52 PM
