Old 10-14-2018, 03:22 PM   #41
2011 22' Sport
Portland , Oregon
Why not leverage the volume of your water heater as well? Pressurizing it provides as much air as volume or more than most portable tanks.
SilverHouseDreams is offline   Reply With Quote
Old 10-14-2018, 03:57 PM   #42
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Good point if using a tankless compressor especially in a pinch. The difference is that once you pressurize the whole system to, say 45 psi; then when opening a fixture, the pressure will start at 45 psi and rapidly drop from there, down to zero, in a matter of 10 or 20 seconds. Whereas the tank in a 6 gallon compressor will pressurize to around 120 psi; then the output valve is set at 45 psi. So when a fixture is opened, the pressure at the fixture will be a continuous 45 psi for 10 or 20 seconds, pushing out water and misty air continously; then once the main compressor tank is below 45 psi, the compressor will kick on and start to build compressor tank pressure again. (This is when I close the fixture to allow the compressor tank to get back up to 120 psi, giving me another 20 or 30 second cycle at a full 45 psi.)
A tankless compressor can work, but just takes much, much longer. Also many of the small compressors have a very short duty cycle (meaning they need to sit and cool off after 10 minutes or so of use.)
pcskier is offline   Reply With Quote
Old 10-15-2018, 06:38 AM   #43
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
Tankless ACs are always on sale at the big box hardware stores during the Christmas buying season. Got mine for $99
twbucksr is offline   Reply With Quote
Old 10-21-2018, 02:48 PM   #44
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this photo show the summer position of the three hw heater valves under the bed
reverse all three for winter
be sure to open the HW tank white plastic drain screw. Beware it may be under pressure
Name:	face view of HW tank- with my suggested summer postions.jpg
waninae39 is offline   Reply With Quote
Old 10-21-2018, 08:43 PM   #45
waninae39's Avatar
2017 22' Sport
NCR , Ontario
just reread the 2017 and 2018 sport owners manual.
it says to tip the front end down as low as it can go and then raise is as high as it can go.
this is the remove all the excess water
does anyone do that.
hard for me as my as is on a sloppy driverway
they also say to disconnect the pipes on the water pump
anyone do that?
Old 10-21-2018, 09:24 PM   #46
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
anyone do that?
Yep.... Level, high, low, then jack the street side...it drained for another 10min or so.👍
No on the WP.
ID:	325881   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 10-22-2018, 10:43 AM   #47
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Jacking
Dropping the front to its lowest point while air is applied to clear the low point drains seems to be a worthwhile addition to my "blow out routine" ...but am wondering about the logic of raising the nose as well as how high is high enough? Jacking from the street side sounds like it's more about getting the maximum drainage that gravity provides rather than an assist for a blow out, or am I missing something?
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 10-22-2018, 10:59 AM   #48
CruizinDux's Avatar
Tracktown USA , Oregon
IMO, the reason for the nose up is to gravity assist the air flow when the rear lp's are open and the nose down for when the fwd lp's are open.
B
CruizinDux is offline   Reply With Quote
Old 10-22-2018, 11:34 AM   #49
2017 22' Sport
Bellevue , Nebraska
Respectfully,
In your posted photo, number 6 appears to be closed. That's the cold water input. When ours (2017) is open, the nubby end is in line with the pipe.
I can't see number 12 at the top, but for summer, that should also be in line for the hot supply to be open. Number 9 is correctly shown as "crossed" and closed for summer (bypass valve). Of course you know your trailer best and if that crossed position is open for you, then the factory was VERY inconsistent in assembly! Here is our summer configuration with the low point drains (not in picture) "crossed" and closed.
PatSoozy is offline   Reply With Quote
Old 10-22-2018, 11:41 AM   #50
2017 22' Sport
Bellevue , Nebraska
anyone do that?
We did (well, DH did while I played with my grand kids in sometimes sunny San Antonio) but he couldn't reach the output on the pump. He said it dumped water from the low point drains under the water heater and the closet.
He did manage to disconnect the input to use the pump to introduce the antifreeze, so he did NOT have to put antifreeze in the fresh water tank. He also followed the instructions to run the pump dry prior to introducing the anti freeze. I'll post again in spring if it turns out that disconnecting the output was a critical step - yikes! BTW, there IS a washer in that connection - ours looks a bit crushed on one side, so we will probably try to find a new one this winter.
Old 10-22-2018, 12:45 PM   #51
waninae39's Avatar
2017 22' Sport
NCR , Ontario
more long posts here in this thread
http://www.airforums.com/forums/f458...rize-7222.html
Old 10-23-2018, 07:04 PM   #52
waninae39's Avatar
2017 22' Sport
NCR , Ontario
be sure to open the cabinet and raise the bottom false floor
you will see the water inlet, ext shower and water pump
between the right side of the ext shower and the water pump are two shut off valves, they lead to the outside under the as 22Fb trailer.
be sure to open these for winter storage as they are the H and C low water points
Old 10-09-2019, 06:35 PM   #53
2019 22' Sport
Santa Fe , New Mexico
Exclamation 2018 Sport winterizing valves
I have done the winterizing checklist Emptied all tanks, fresh water, black and grey.Am now opening exterior Water Heater valve, manuals talk about valves in closet and foot of bed????Have put RV antifreeze in sink, shower and commode..I cannot identify the referenced valves in the closet or at foot of bed..neither the dealer or Airstream H Q have returned my calls..we are in for 26degrees tomorrow night..the unidentidide valves are a concern..and do I need to turn on the water pump to circulate the anti freeze? Sure appreciate any response
Cherokee88 is offline   Reply With Quote
Old 10-12-2019, 10:59 PM   #54
Those valves are there look harder they are to the right of the water heater and also under the access panel in closet between black tank and water pump. If you look under the trailer you will see red and white tubing coming out, these are them.
Kanusport is offline   Reply With Quote
Old Yesterday, 04:07 PM   #55
2018 22' Sport
Lakewood , Colorado
I have a Sport 22 that I am living in. The weather is getting cold. We moved back on grid yesterday. Today we wrapped the base of the trailer in a reflective foam insulation. We put two halogen lamps under the trailer. The lightbulbs are not LED and they kick out some heat. I plan to keep a small heater on inside the trailer. Does anyone think we can avoid frozen pipes with this strategy? Any idea how low we might go before needing to drain the pipes?
Meli H is offline   Reply With Quote
Newbie Questions on my Sport 22FB - Batts, Solar Aerodmb 2005 and newer - Bambi all models 1 06-29-2018 01:53 PM
22FB Sport :: 2012 Airstream Sport Bonita Airstream Registry Discussions 0 03-29-2017 02:23 PM
Wiring questions for a Sport 22FB Rpatrick16 Batteries, Univolts, Converters & Inverters 8 05-10-2016 09:59 AM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
