Old 08-24-2016, 01:31 PM   #1
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Sport 22FB - Dometic 3-way Fridge - Storage
I believe that the Sport 22FB is the only current model AS that has the automatic, 3-way fridge (12v, LPG, 120v). BTW, the 12v seems to work well when travelling and my Jeep heavy duty alternator seems to be able to keep up with the draw.
The only PDF manual that I was able to find online with a similar Dometic fridge has the following photo with this description of operation for storage: "Release the locking mechanism of the door lock by pushing it and shift it to the front. If the door is shut in this position, a small gap is nevertheless kept open to prevent formation of mildew.
Name:	Dometic 3-way Door Catch.jpg
When putting the coach into storage for a few weeks I like to have the door held partially open to prevent mildew from forming inside. This mechanism works to hold the door open, but prevents it from opening more or closing. The door is unlatched in the usual way by pressing the release on the top of the door.
I was able to get this mechanism to move into the storage position, but had to partially remove the clear plastic cover in order to get the latch gate to move forward. Is there a trick to make this operation easier?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 08-25-2016, 06:13 AM   #2
2017 22' Sport
Florida , Florida
Thanks for posting this. Just picked up a 22FB and was going to get one of those plastic door props. I will take a look at my fridge later this week.
sm171 is offline   Reply With Quote
Old 08-25-2016, 08:16 PM   #3
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
I find that we can just not really close the door completely when we store, and it has been fine.
Only issue we have had with the refrigerator was the door open sensor not realizing that the door WAS closed during camping, which leads to the alarm beeping once a minute or so. Quite annoying. A trip to Google lead me to wad up a small bit of duct tape and cram it into the slot, so that the door catch pushes it in deep enough to trip the door close sensor.
Hope that you enjoy your 22 as much as we do.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-26-2016, 01:36 AM   #4
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
I have taken our "Chick" in for service on this beeping refrigerator door alarm 2 times under warranty. Service Advisor at the Airstream dealer says Dometic won't let him replace the part. Not sure what the dealership is doing to fix the problem but the first fix lasted a few trips. One the second fix now. Thanks for the heads up on the Google search for a duct tape fix Piggy Bank.
twbucksr is offline   Reply With Quote
Old 08-26-2016, 02:43 PM   #5
2010 22' Sport
Boise , Idaho
I am very familiar with the mechanism that you are referring to and have pictured in your message. I couldn't get mine to work either until I really soaked it with a silicon lubricant that is suitable for plastics. It is still really stiff but it works.
baldwin6601 is offline   Reply With Quote
Old 09-26-2016, 09:33 AM   #6
2017 22' Sport
Florida , Florida
I tried the storage latch on my fridge for the first time this weekend. The latch was a little tight at first, but works great now.
Old 07-24-2017, 06:09 PM   #7
LuLuAdrift's Avatar
2016 22' Sport
Leesburg , Florida
Mine started doing this this morning. Same as you. Dometic says door sensor or control board. Board is $500. A month for door sensor (Don't know cost) No luck yet with duct tape.
LuLuAdrift is offline   Reply With Quote
Storage under dinette & water connections. Sport 22FB Adanac 2005 and newer - Bambi all models 12 08-15-2015 04:01 PM
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
22FB Sport propane storage capacity upgrade? Skipjackrick LP Gas, Piping, Tanks & Regulators 6 08-31-2012 08:18 AM
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
