Old 08-29-2017, 10:17 AM   #1
camperguy58's Avatar
Folsom , California
Sport 16 Tire Safety
Have read lots about trailer tire blow outs and upsizing to 15" tires. A few questions for 16 owners about tire safety.
1) Has anyone changed out to a different tire in the same size? Like Maxxis M8008 Radial (rated for higher speed), or Provider ST215/75R14 Radial Trailer Tire - Load Range C
2) Thoughts on upgrading to a D rated tire (from the stock C's)? Like Provider ST215/75R14 Radial Trailer Tire - Load Range D
3) Speed limit with a trailer is 55 (in California) although no one does that. What speed do you normally drive?
4) Any lessons learned that can make 14" tires safer?
Thank you in advance for your help.
Pat
In between campers
2017 Honda Ridgeline Black Edition
Folsom, CA
camperguy58 is offline   Reply With Quote
Old 08-30-2017, 07:49 AM   #2
2015 16' Sport
Jacksonville , Florida
Yesterday I replaced my tires on 2015 Bambi with Goodyear Endurance 14". I keep my speed around 60 mph. I check tires frequently when traveling.
Mageliza is offline   Reply With Quote
Old 09-03-2017, 02:51 PM   #3
larry9000's Avatar
2006 16' International CCD
Steamboat Springs , Colorado
I also upgraded to the GY Endurance D rated tire when we got our 2006 Bambi. From reading the issues with the GYM, dual axle trailers had bigger issues, but I didn't want to take chances. I also put in a set of tire temperature monitors.
2006 16' International CCD pulled by 2016 Toyota 4runner
larry9000 is offline   Reply With Quote
Old 09-04-2017, 11:00 AM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i added an eez tire monitoring system with 6 wires probes
every 5 seconds it sends me each of the 6 tire pressure and temp.
you set a low and high alarm for each axle.
blowout or slow leak will be detected and alarmed to you quickly
waninae39 is offline   Reply With Quote
Tire Safety Factors switz Tires 38 12-02-2012 03:23 PM
Flat tire safety bars vanster 1969-1971 Caravel 12 10-17-2012 08:59 AM
Airstream Sport 22 :: 2011 Airstream Sport Lone Eagle0 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Tire Safety Message lewster Tires 0 06-26-2007 10:07 PM
Trailer tire safety article 83Excella Tires 0 08-14-2002 08:44 PM
