Old 03-17-2013, 04:50 PM   #21
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by Off-we-go View Post
No problem, I can post some pictures on Monday evening.
Thanks.
interstateflyer is offline   Reply With Quote
Old 03-19-2013, 06:41 AM   #22
Off-we-go's Avatar
2007 19' Safari SE
Marina , California
Originally Posted by interstateflyer View Post
Thanks.
Here are the pictures of the major components of my system, panels on the roof, battery box mod to accommodate the two deep cell batteries and the charge controller
Off-we-go is offline   Reply With Quote
Old 11-27-2013, 05:37 PM   #23
GP1152's Avatar
2015 23' International
Sacramento , California
I know this is some months old, so I'm hoping that everyone contributing to this is subscribed and will see this. If so, I'd be curious as to the total cost of the units mentioned above. With and/or without labor?? Thanks!!
GP1152 is offline   Reply With Quote
Old 11-30-2013, 06:55 AM   #24
Off-we-go's Avatar
2007 19' Safari SE
Marina , California
Total cost was $3,014.60, labor was $975.00
Old 03-13-2014, 09:12 PM   #25
ottawa (greely) , Ontario
I have solar at home and I'm thinking of putting solar on my. 2012 19 foot flying cloud, what I have learned from at home the cheapest way is to conserve,use high efficient light,appliances etc such as led lighting ,led t.v. ,, the roof of a 19 foot trailer doesn't have much space to install panels ,the factory installs a 53watt panel it's not much but it can keep your batteries charged while not using the trailer and if you get a mppt charge controller such as midnite solar (the kid) this charge controller can get the most out of any solar panel and will get the most life out of your batteries by doing bulk charge ,absorb charge and float charge ,also you can do the most important charge cycle equalize charge used to equalize all cells in the batterie and to prevent batterie sulfation by stirring up the acid , don't get me wrong 53 watt solar panel can do a lot if exposed to the sun at correct angle , I run a 60 watt panel at a remote cabin and it runs all my lights ,charges cell phones ,laptops,runs a small t.v, electric shaver, but you must conserve also you must have at least two deep cycle batteries, and don't run them below 50% charge or you will shorten there life! and if you have a cloudy day power is drastically reduced!but a 53 watt panel will be great it will extend the life of your batteries ,will protect them from freezing witch could damage them if discharged and exposed to freezing temp by keeping them charged , at home I have 1260 watts of panels ,12 glass mat deep cycle batteries, a 3600 watt pure sine inverter,a midnite solar 96 amp charge controller and on a good sunny day it produces over 10 kilowatts per hour . Witch runs almost everything in the house but heavy appliances on 220 volt. Also I mentioned the charge controller mppt from midnite solar (the kid )it can charge 12 volt to 48 volt batteries and also you can hook up your solar panels in series for higher voltages means smaller wires can be used so you don't have to rewire you trailer, that's if it is prewired for solar also smaller wire gauge saves on cost of wire ,and higher voltage means longer wire runs with same wire size,less voltage drop for higher voltage.
scamp is offline   Reply With Quote
Old 05-13-2015, 06:52 PM   #26
2005 19' Safari
2003 28' Classic
Port Lavaca , Texas
Not to get off the subject of solar panels but I noticed you have stabilizer bars on your 19' ???. I just bought a 2005 - 19' and have not had it out on the road yet other then the 75 mile trip bringing it home. It towed fine, really no swaying but it was not that windy either. Did you have a particuler reason for getting them?
Attachment 181372
Attachment 181373
Attachment 181374
dugan is offline   Reply With Quote
Old 05-14-2015, 09:37 AM   #27
Off-we-go's Avatar
2007 19' Safari SE
Marina , California
That is a Hensley Cub anti-sway hitch that offers safety and peace of mind when towing. It's just an addition level of safety. Just Google Hensley Cub for additional information on anti-sway towing.
Old 05-18-2015, 11:51 AM   #28
I've used them on a variety of trailers over the years and have noticed increased stability under quick braking, down hills and in the wind, natural and semi truck induced. If properly setup and adjusted, they distribute the weight evenly between the front and rear axels of your tow vehicle, for better handling and tire wear.
I recently switched to the Equalizer brand WD system on my 2014 23D. Pricer than Huskey and other chain based systems but more effective and much more convenient to hook/unhook. Equalizer has built-in sway control.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
Solar prewire location 2006 16' Bambi CCD KiwiAS Generators & Solar Power 2 02-28-2014 06:47 PM
2010 Airstream 19 International Signature Bambi REPO eBay Watch Airstreams on eBay 0 01-06-2012 08:40 AM
2006 Airstream International Bambi 19' eBay Watch Airstreams on eBay 0 10-06-2011 11:00 AM
Rosco :: 2004 International CCD Bambi Grizzly6 Airstream Registry Discussions 0 08-19-2011 09:31 AM
