Old 05-25-2019, 09:04 AM   #1
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Socket for Lug Nuts
Do I need a special socket for my Sport 16's lug nuts? They are 13/16"'s. Thanks!
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 05-25-2019, 09:13 AM   #2
Mollysdad's Avatar
Depending on the rims you may need a thin wall socket if the nuts are recessed in the rim.
I also use a short extension (3") and a breaker bar.
Mollysdad is online now   Reply With Quote
Old 05-28-2019, 09:38 AM   #3
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Thank you!
Kim
Charlotte, VT
Old 05-28-2019, 12:00 PM   #4
Long Island , New York
Might also need to be a "deep" socket. Ditto to using a 6" extension from the socket to a breaker bar [or torque wrench, if you are at that stage].
Also, a six-point socket is better than a twelve-point, which is more prone to not fit correctly, and can "strip" the lug nut/bolt, especially the chrome-covered ones [see below].
When you confirm the correct socket size, you might as well get a spare, especially if you have to use a "thin wall" version. BTW do you have the lug nuts/bolts which have the chrome covers over the "real" item? They fail at the worst times, so we replaced the "fake" lug nuts/bolts with solid SS ones.
"solid lug nuts bolts" --
https://www.google.com/search?q=soli...com&gws_rd=ssl
Peter
PS -- 1/2" drive for all socket stuff, not 3/8."
Old 05-28-2019, 12:17 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
13/16" is also a common size for sparkplug sockets. They are deep sockets, 6-point, and usually thin too. Easily available online or at any auto parts store.
They usually have something to keep the sparkplugs from falling out, most often a piece of stiff foam tube that may or may not get in the way when used for lug nuts, but they slip out easily.
For use on lug nuts, I would recommend ½" drive rather than ⅜", both sizes are commonly available.
Vaughan
Old 05-29-2019, 04:14 AM   #6
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Peter
Wow, thank you Peter. Had no idea about the "fake" bolts. I just keep learning, in drip and drabs!
Kim
Charlotte, VT
Old 05-29-2019, 04:15 AM   #7
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Great. Thank you so much Vaughn.
Kim
Charlotte, VT
McGard Lug Nuts @ Lock nuts PSU1981 Wheels, Hubs & Bearings 1 12-13-2018 07:13 PM
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 09:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts sepezlover Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
