Old 10-02-2019, 07:00 PM   #1
2019 22' Sport
Tabernash , Colorado
Silly shower door
This may be the silliest problem yet, but it does cause an issue in that we cannot close the shower door. The hole for the door is approximately 1/2 inch above the small post that holds it. Unfortunately, we get water coming out of that small opening.
And yes, I have pulled, pushed, tugged, and attempted to do everything for them to line up. Has anyone had this same issue? And knows the quick fix?
Jeff
JeffCross is offline   Reply With Quote
Old 10-03-2019, 11:43 AM   #2
FYS
2016 20' Flying Cloud
Walnut Creek , California
Is your trailer parked leveled?
Can't move the catch-hole, but maybe you can relocate the plastic bolt piece?
FYS is offline   Reply With Quote
Old 10-03-2019, 07:09 PM   #3
2019 22' Sport
Thanks. We are parked level in the driveway. I
Am just looking to silicone over the old screw hole and screwing in “the nub” in the correct location. Seems like the easiest fix.
Old 10-07-2019, 04:16 PM   #4
Msherw's Avatar
2018 22' Sport
Blue Sky Ranch , Texas
Jeff
Jeff, was it this way from day one? If not, something has 'slipped' and lost the alignment - may be either the frame or the receiver post.
Being a 2019, you have 3 years of warranty. Might be good to take it to the dealer and have it checked for a much greater issue. Just moving the nib will fix the results but not the root cause.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
Ham Radio Call sign K5FT
WBCCI #18673 - of Texas group
Msherw is offline   Reply With Quote
Old 10-11-2019, 12:17 PM   #5
2019 22' Sport
Fairhaven , Massachusetts
Jeff, my shower door does the exact same thing. I find that by latching the door on an angle, lifting the door very slightly when pulling the door shut from inside the shower, it will latch. I consider it another idiosyncratic feature to learn on the trailer. The top frame of the shower door also kept popping out, which was held in place with just caulking. I ended up riveting it in place.
davincent is offline   Reply With Quote
Old 10-11-2019, 12:24 PM   #6
2017 16' Sport
Canyon Country , California
shower curtain over door not working?
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 10-11-2019, 02:18 PM   #7
Acton , Ontario
Mine does the same and I know what the problem is. At the top right corner of the frame the upper channel has popped up. I always re-seat (difficult at times) it and the door closes fine afterwards. It only secured in place using double sided tape. I plan on fixing it permanently by drilling a hole and adding a rivet. I'll probably do it this weekend while fixing the last 2 rivets that pooped out during our last trip.
sinfulpride is offline   Reply With Quote
Old 10-18-2019, 10:11 AM   #8
2019 22' Sport
You were absolutely correct, the right front corner had popped up and out. When I looked at it more closely it was a fairly easy fix. We will see if it stays as we head out tomorrow for 3 weeks. If not, I will like you drill a hole and add a rivet.
Old 10-18-2019, 12:45 PM   #9
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we replaced flexible shower door in our 22fb with a solid plexiglass model.
most AS use the exact same door
not that hard to retrofit
waninae39 is offline   Reply With Quote
Old 10-18-2019, 02:14 PM   #10
2017 22' Sport
Round Hill , Virginia
Any more details, or a link? I truly hate the accordion door.
thetable is offline   Reply With Quote
Old 10-19-2019, 06:12 AM   #11
Acton , Ontario
I've popped it back countless times. I did drill and rivet it and it works fine now.
quick silly question! EoinmcCabe Buyer Guidelines 5 02-05-2010 08:17 AM
Ready to strip! Silly, not me - my '73 Overlander funkill Cleaning, Stripping & Polishing 1 07-31-2009 12:07 PM
Silly Dometic refrigerator "problem" Toasty's Dad Refrigerators 0 12-20-2005 08:19 PM
silly ball height question. AV8 Hitches, Couplers & Balls 7 11-09-2003 06:32 PM
