Old 08-30-2015, 12:02 AM   #29
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I carry both. The ss is the back up plan.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 08-30-2015, 01:17 AM   #30
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I also carry both, but the slinky is the back up. In ten years, I have used the slinky twice and only for gray water.
Brian
SuEllyn & Brian McCabe
Old 09-05-2015, 08:20 AM   #31
skitique's Avatar
1974 Argosy 26
1990 34' Excella
Charleston , South Carolina
Originally Posted by AWCHIEF View Post
Suggestion that I read about somewhere on the Internet. The black tank is not a septic tank. It is a holding tank. Most commercial RV holding tank products are repackaged chemical or enzyme based septic tank products. After dumping and flushing, add 1 cup each of Calgon water softener, liquid dish soap and bleach with 1 gal of water. Add to tank. It is supposed to lubricate, clean and sanatize in one step. I am currently trying it for the first time. So far seems to be working ok.
Michael,
Did you try cleaning your tanks with Calgon, soap, & bleach?
I flushed ours with the wand & added lots of cleaner & the smell got better but didn't go away. Now after storing the AS the smell is worse again. The odd thing is when we camp & use the black & grey water tanks there is no smell at all. Not sure that helps me solve the smell issue but it does seem odd. Where did you find Calgon? Didn't see at the grocery but will try Walmart.
Jane & Scott
skitique is offline   Reply With Quote
Old 09-05-2015, 08:36 AM   #32
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
It does not have to be one or the other. I have been using both the SS and slinky for 4 years as the situation dictates.
Quite right. We don't often visit campgrounds with full hook-ups but when we do, the sewer connecting point is usually too high for the slinky to work well, hence our use of the excellent SS. Yes, it's slow, but what's the rush?
The slinky stays on board for use at the communal dump station.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 09-05-2015, 09:02 AM   #33
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
J&S, been using the concoction all summer. So far so good. I think I did get the Calgon at Walmart. They had liquid. Have not seen the powered anywhere.
MICHAEL
Old 09-05-2015, 01:40 PM   #34
chaseav's Avatar
2015 25' FB International
Originally Posted by skitique View Post
Michael,
I've had this problem before too. It was because I was unable to use the in-tank-water-swirler-muh-bob. Once I got to a good sewer with unlimited fresh water I hooked it up and was blown away by what came out. I knew it would be gunked up but this was like days worth of... solids... I could never get the tank sensor to read lower than 10%. And that's why!
I assume if you had one of those you'd be using it though and would not have this issue. Maybe try the old bag of ice trick as an alternative.
chaseav is offline   Reply With Quote
Old 09-05-2015, 01:45 PM   #35
AWCHIEF's Avatar
Images: 33
You would have to search but there is a video on YouTube that purports to prove the the ice trick is nothing more than old wives tale and does not work. I have never tried it so have no actual experience or opinion.
MICHAEL
Old 09-05-2015, 06:26 PM   #36
2016 30' Classic
Maitland , Florida
Okay, newbie question from someone who doesn't have their trailer yet. How do you add a mixture to the black tank? Through the toilet or is there another intake place?
FreshAirStmr is offline   Reply With Quote
Old 09-05-2015, 06:37 PM   #37
skitique's Avatar
1974 Argosy 26
1990 34' Excella
Not quite sure what you are referring to. Does this extend into the tank through the toliet?
Old 09-05-2015, 06:40 PM   #38
AWCHIEF's Avatar
Images: 33
Dumped down the head.
MICHAEL
Old 09-05-2015, 08:13 PM   #39
2007 22' International CCD
Translation for non-Navy types:
Flush the additives down the toilet like normal use.
KE4GNK/AE
Old 09-05-2015, 08:40 PM   #40
chaseav's Avatar
Name:	ImageUploadedByAirstream Forums1441507183.862977.jpg
This thing...
Old 09-05-2015, 08:41 PM   #41
chaseav's Avatar
I should probably give credit to that video: http://youtu.be/8GJgI0yS4uM
Old 10-28-2016, 10:04 AM   #42
Dino & Mike
Stream-Style's Avatar
Northridge , California
Sewer Dump Virgin (me ) question regarding Sewer System:
Do all, or most "sewer dump stations" at RV/camp sites also provide a water hose-bib to use at the dump-station?
And does the Sewer System work uphill because of the hose-water force down the 1" black tube or is it just the act of bigger pipe reducing to smaller 1" hose somehow do it?
"Life a is banquet, and most poor sons-of-bitches are starving to death" ...Auntie Mame
Stream-Style is offline   Reply With Quote
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 07:05 PM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
"sewer solution" Chuck Waste Systems, Tanks & Totes 17 08-29-2002 09:17 AM
