Old 03-24-2018, 10:06 AM   #1
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Second striker board out on 22FB water heater
Had the 22FB only 3 months and the electronic striker board died. Dealer shipped me a second one. It lasted only one trip out. Now it has died.
Called Atwood and ran through full tests of the feed lines, power supply, and solenoid over the phone. AS wiring ok. Then I was told Atwood had many problems with striker board models ending in -8E. The tank is a 6 gallon propane only.
Atwood is sending a 3rd board to a mobile repair guy to install. They are footing the mobile fee and 30 minute install rate. Atwood will not ship any part to end users as a policy. Growl Growl. Itís costing Atwood $160 + new board. As I have extensive electrical and electronic background I could have saved them money.
All this to say, if you lose a striker ignition board model ending in -8E, or even two, it is apparently a poor design and since the board is potted it cannot be repaired.
Unless you guys have some thoughts on the matter...
M!ke
2018 Sport 22FB / Toyota 4Runner V6
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign NO5Y
Msherw is offline   Reply With Quote
Old 03-24-2018, 03:34 PM   #2
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
we had the same issue
we paid a RV tech to do its just so that we could get the warranty refund.
The tech did not want to charge us since it was so simple. he said, fine, i;ll make you a bill for a wauarntee claim.
we both smiled
it look less than 1 min to replace
waninae39 is offline   Reply With Quote
Old 03-25-2018, 08:59 PM   #3
2016 22' Sport
Clinton , Montana
What does this striker board look like? Can you post a photo? Finally where does it go on the water heater? Thanks in advance for your response.
Pat
Rpatrick16 is offline   Reply With Quote
Old 03-26-2018, 06:58 AM   #4
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Pat it is the 3x4 black board with a wiring harness on one side and a single wire connected to the flame chamber. The single wire provides a strike/sense path to turn on the gas solenoid.
If it all works you hear one gas solenoid click on, gas flows, and a tick tick tick as the striker attempts to light the propane flow.
If it is successful the same wire sends a signal to the board to keep the solenoid on. If not, it shuts the solenoid off then repeats the cycle 2 more times before it times out.
Both my boards failed to strike/sense and then go into time out. Even lighting with a bbq lighter the sense doesnít register the flame and shuts the flame off.
Iíll post a photo if I have time.
M!ke
Old 03-26-2018, 08:47 AM   #5
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
What I think is you are getting better response and service than a lot of folks report on other issues. Any chance your technical knowledge helped smooth the process or were you just lucky enough to have the problem after Atwood accepted it existed?
In any case. Thanks for posting. Good information. Really helps when folks understand what to expect. Pat
Old 03-27-2018, 08:58 AM   #6
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
The offending board is shown. It is potted so most components cannot be seen.
Update: Got the 3rd one installed yesterday. Worked overnight. We shall see...
M!ke
Old 03-27-2018, 09:55 AM   #7
2017 27' International
Lake Havasu City , Arizona
"it is apparently a poor design."
Exactly--and replacing a poorly designed board with another poorly designed board is a losing proposition. But there's a better alternative.
When replacing the controller/igniter/"striker" board on a furnace, water heater, or propane refrigerator, get a replacement made by Dinosaur Electronics. They are better designed and built than the original manufacturers' boards.
I've done several Dinosaur board refits for myself and friends, and have yet to see one fail. RV techs I know recommend them. For your water heater, I believe you'd need their UIB-S or UIB-64 board--check with Dinosaur. Their tech support is excellent, by the way.
Paprika is offline   Reply With Quote
Old 03-27-2018, 10:34 AM   #8
2002 19' Bambi
Lafayette , California
Another vote for the Dinosaur boards. We did not have a problem with our water heater's board, but the furnace board was another matter. After the failure within a short period of time of two original boards, we installed a Dinosaur board. Still no problems after many years!
Tim
Tim A. is offline   Reply With Quote
Old 04-08-2018, 05:59 PM   #9
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
New striker board has been installed 2 weeks and seems to be working fine. Exercise it every day. Leave on a road trip next week.
I appreciate the info on the Dino boards. If the #3 board fails, I will be ordering a Dino, warranty or no warranty. Tired of the inconvenience of cold showers on the road.
Airstream take note: I think Atwood is trying but their batch of bad striker boards is making your decision to use them in the AS very questionable. 3rd party failures reflect on the overall RV experience.
M!ke
Old 04-08-2018, 08:28 PM   #10
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I went through 2 Atwood boards for my HW heater. Same issue although I was able to light the unit manually with a BBQ lighter. Atwood sent out a mobile tech to troubleshoot before they would send a board, which they only would send to him. The reason is not because of warranty, it was because itís a propane device. Anyway, not wanting to wait I had the tech install a Dinosaur board. Works like a champ. He delivered the replacement Atwood board as a spare- doubt Iíll ever open the box. It probably doesnít work anyway.
VaTravelers is offline   Reply With Quote
Old 04-09-2018, 01:03 PM   #11
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
here are the instructions to replace atwood h/w heater circuit e board
if the fails a 2nd time, open a claim with AS, tell them you want another OEM supplier
Name:	atwwod hw heater-1.jpg
ID:	308272   Click image for larger version
Name:	atwwod hw heater-2.jpg
Old 04-10-2018, 06:30 AM   #12
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Actually Iím on the 3rd board. If it fails, a Dinosaur board will replace it.
M!ke
Old 04-12-2018, 02:34 PM   #13
2018 22' Sport
Broomfield , Colorado
I went through two boards on our 2018 as well. 3rd has been a charm so far..
SkiCO is offline   Reply With Quote
Old 04-14-2018, 05:54 AM   #14
OriginalMrT's Avatar
Orland Park , Illinois
I am thinking this may have struck us. Water heats on electric but is a no go on propane. Three attempts then solid red. Is there a quick diagnosis? Do the little LEDs above the fuse indicate anything? Heading back to Chicago from San Diego in 2 weeks hot showers would be awesome.
Mark
OriginalMrT is offline   Reply With Quote
Door striker Rivets bwbuer Doors & Locks 3 03-12-2011 07:35 AM
Is this door striker available? vhord Doors & Locks 28 04-28-2008 06:38 PM
Pictures of '64 door striker? 59er Doors & Locks 2 12-03-2007 01:06 PM
Screen door striker Robfike Classic Motorhomes 5 06-03-2006 06:26 PM
Striker Rod for '66 Overlander draftwomyn21 Refrigerators 6 05-21-2006 08:20 PM
