Old 03-30-2019, 10:04 PM   #1
Boise , Idaho
Screws for window rock guards.
Has anyone had trouble with re-tightening the screws that hold down the window rock guards after cleaning? I was able to get mine to hold, but instead of a 1/4 turn it felt like I had to turn it much more than that to get it tight. I'm not sure how these screws work so I was wondering if that was normal.
I've read in other forums that buying the longer screws can help make it easier to reinstall them. Does anyone have a link where I can buy the longer ones?
Thank you!
James3344 is offline   Reply With Quote
Old 03-31-2019, 03:34 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What were you doing removing the screws in the first place? That's not how you remove the rock guards to clean them.
If you are talking about the pair of latching screws to release them, if you turned them more than a quarter turn, you destroyed the latch, and it will have to be replaced.
Old 03-31-2019, 05:26 AM   #3
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
The first time I washed my windows, the flimsy little connections on the window guards stripped and I couldn't reattach them. Here is how I permanently fixed the window guard connections.
I basically copied the through-bolt method from the stainless steel rock guards. First I drilled out the rivets holding the rubber grommet connectors on the Airstream. Then I went to the hardware store and bought stainless steel screws, washers, and locking nuts that fit through the stripped out hole on the rubber grommet connector. One lock nut went against the washer on the rubber grommet. Then I re-riveted the grommet back on the Airstream and put the second locking nut onto the bolt after closing the window rock guard.
Now I can easily clean my windows and know they are securely attached afterwards. I highly recommend doing this improvement. These pictures are worth a thousand words.
http://www.airforums.com/forums/atta...4&d=1503173972
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 03-31-2019, 09:06 AM   #4
Boise , Idaho
Yes i'm talking about the latching screws. If I destroyed the latch would they still be able to tighten down? Right now they feel pretty secure, but I felt like it was more effort than it should have been to get them tight.
Old 03-31-2019, 09:37 AM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Thank you!
Some people (including dealers) shave off some of the rubber post so that you don't have to push as much to latch the stone guard.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 03-31-2019, 03:42 PM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
yes
i HATE that BAD design
we and all dealers have issues
no one can get then to lock on our as 22fb
all we do now is close the side window and use the centre window from having the side windows open
waninae39 is offline   Reply With Quote
Old 03-31-2019, 04:03 PM   #7
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I ordered several spares from Airstream. AS sent the entire assembly, not just the "screw". They shipped them at no charge.
They are a big pain to get to work. You really have to pay attention when you mate the "screw" with the bracket. 1/4 turn only or they break.
If you break one on a trip, you can temporarily wire them.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is online now   Reply With Quote
Old 03-31-2019, 05:20 PM   #8
Boise , Idaho
I'd like to have spares on the road as well. How did you order them and have them shipped at no charge?
Old 04-01-2019, 10:28 AM   #9
1996 25' Excella
Tillsonburg , Ontario
I Had trouble with my '96 so they haven't changed the design much. I doubt you have destroyed the screw. I did the same thing and once I figured out how they work the quarter turn was just fine. Have traveled 3000 miles with no issues.
JCW
JCWDCW is offline   Reply With Quote
Old 04-01-2019, 10:40 AM   #10
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Hoo yah excellent picture story.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 04-01-2019, 10:51 AM   #11
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
They are called Dzus fasteners made by Southco. I ordered some a few years back direct from Southco. There are a lot of styles. southco.com
Streamracer is offline   Reply With Quote
Old 04-06-2019, 04:35 PM   #12
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
AS Warranty folks are pretty good about sending replacment parts that fail under warranty...if you call the factory. That's assuming you have a newer model...I have had them send me a few different parts over the past 4 years...free.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Manufactured and Installed Window Rock Guards coloradopete Rock Guards, Segment & Window Protectors 7 10-08-2016 04:00 PM
Window Rock Guards Mike25FB Windows, Doors, Locks & Vents 4 01-21-2016 04:49 PM
Cracks and one hole in 2015 Airstream window Rock Guards Mike25FB General Repair Forum 8 01-01-2016 12:01 PM
Window rock guards.... warp Gator113 Rock Guards, Segment & Window Protectors 13 03-09-2015 05:20 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
