Old 06-12-2015, 06:17 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
Running TV off battery in Bambi Sport 16
I was wondering if I could run the Samsung Television that came with my 2015 Bambi Sport off of just the battery? It looks like the TV Is 12v but presently only runs on shore power or through an inverter. I thought I read on a thread somewhere that if I purchased or made a cigarette lighter adapter plug I could run the TV off the battery. The 2015 Sport 16 doesn't come with a 12v plug, but I switched one of the USB plugs for one. I also read that a 12v regulator would help keep the RV from wigging out from voltage fluctuations. Any thoughts on how to run the existing TV off battery?
tjwoods1 is offline   Reply With Quote
Old 06-12-2015, 07:09 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
IF the TV has a separate power supply and sends 12V DC to the TV, then all you need to do is make a cable to run from the cigarette lighter socket to the TV. If you still have a Radio Shack in your area, take the TV power supply to them and have them get you the parts you need, particularly the plug for the TV. Unless the power supply sends 12V AC to the TV you will need to observe polarity. Either the TV or the power supply or both should have a diagram showing which part of the TV connector is positive and should be connetcted to the tip of the cigarette lighter plug. In most cases, the center of the TV plug is positive, but not all, so you must be careful or you could kill the TV.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 06-13-2015, 08:50 AM   #3
2016 22' Sport
Sandpoint , Idaho
TV on 12V
Our 2011 16ft has a 120V tv set. We have used a small inverter to power it. Can't do it for a long time, esp with heater on, unless have solar to recharge next day. So, TV set draws little enough to run with small inverter, but the larger question is your overall 12V drain and charge. Try never to take battery down more than 50%, otherwise its life is reduced a lot.
Yachthalo is offline   Reply With Quote
Old 10-25-2015, 08:49 PM   #4
ottawa (greely) , Ontario
What I did is replace the t.v. Antenna amplifier wall plate with a upgrade wall plate that has a 12 volt power outlet , then I bought a small 75 watt power inverter that plugs directly into the TV wall plate amplifier 12 volt plug and voila! Just plug the TV 120 volt cord into the inverter ,took a whole 5 minutes to upgrade the TV amplifier wall plug! I got it from Amazon it's a original wine guard wall plug - amplifier outlet. No modifications ,mounts in original location no drilling .
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-03-2016, 11:16 AM   #5
Boxite's Avatar
2008 22' Sport
Many smaller TV sets are actually 12V DC already... they simply have a pwr supply built into the cord to convert the 110 VAC to 12V DC for the television's use. Check yours closely. If it uses a corded pwr supply (such as many laptop computers) you may find that to be the case. In such cases, a simple cigar-lighter type plug is probably all that is needed. (In fact, if you have purchased an after-market TV then the packaging probably included such a cord.)
The data-box on the rear of your TV should indicate the voltage and current requirements.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 04-28-2017, 04:04 PM   #6
2016 16' Sport
Miami , Florida
Had to bring this back to life.
I have a 2016 sport 16. Is the 📺 supposed to work on battery power?
Shiny16 is offline   Reply With Quote
Old 04-28-2017, 10:23 PM   #7
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Shiny, do you have an inverter? You need an inverter to run the TV off batteries
Troutboy
Troutboy is online now   Reply With Quote
Old 04-29-2017, 05:31 AM   #8
2017 16' Sport
abita springs , Louisiana
I have 2017 Bambi. Tv needs 16 volts. Runs nice on small inverter and small draw on batteries
jsabatier is offline   Reply With Quote
Old 04-29-2017, 05:54 AM   #9
2016 16' Sport
Miami , Florida
No inverter. I just thought that the TV was a 12 volt TV.
Old 04-29-2017, 05:55 AM   #10
2016 16' Sport
Miami , Florida
What kind of inverter and did you install it somewhere or just plug it in.
Old 04-29-2017, 06:16 AM   #11
2016 16' Sport
Miami , Florida
Don
I just found this.
https://www.amazon.com/OUTLET-ANTENN...Y2HTJC48FTB066
Old 04-29-2017, 09:19 AM   #12
2017 25' Flying Cloud
Gold Country , California
Hi shiny! No, your TV will not work on battery as it comes from the factory. On our 16', I installed a small inverter near the TV and used that. I've seen others get 12v from the antenna switch and use a cigarette style inverter.
NorCal Matt is offline   Reply With Quote
Old 04-29-2017, 09:20 AM   #13
Sorry, I hadn't refreshed since last night.
Old 04-29-2017, 09:38 AM   #14
2016 16' Sport
Miami , Florida
Thanks guys.
2013/2014 Bambi Sport 16' Sport Wrap Windows in back? maureencrist 2005 and newer - Bambi all models 7 04-21-2014 08:46 PM
3.0 Amp CPAP machine running off a Marine battery Lothlorian Off Topic Forum 9 08-15-2010 10:02 AM
battery switch off - fridge running Joyce and Jim Batteries, Univolts, Converters & Inverters 4 08-28-2009 08:35 AM
Running trailer directly off Univolt (no battery) wacnstac Electrical - Systems, Generators, Batteries & Solar 8 11-08-2008 11:35 AM
only partial DC when running off battery jeff&jess Batteries, Univolts, Converters & Inverters 8 03-06-2007 07:30 PM
