Replacing MicroPulse tank sensors and tank access on 22FB
We have a '11 22FB, up until recently I didn't know that there was such a distinct difference in tank monitor options that were used in various model years. We have MicroPulse sensors, which do not work well at all...and after reading discussions on the subject seems to just not be capable of working well. I am sure that on a RV/TT with 40G holding tanks you can accept less accuracy, however the tanks on a Sport are small enough that losing 1/4 tank of visibility does matter. This came up as in our most recent trip we went from having a monitor report the gray water tank as being 1/8 full to the shower having standing water and the monitor reporting full...
I see that the LevelSee monitors are are superior, I am curious if anyone else has done this on a 22FB. Getting adequate access to the tanks is the challenging part, sticking the LevelSee monitors on shouldn't be overly difficult nor should the wire splicing, etc. I have tried searching for any threads on the subject of accessing the tanks on a 22FB with no luck.
Hopefully someone has approached a similar task, either to repair a tank, valve, etc and can share some wisdom on the best approach to access each of the 3 tanks.
