Old 06-20-2018, 10:58 AM   #1
2011 22' Sport
Portland , Oregon
Replacing MicroPulse tank sensors and tank access on 22FB
We have a '11 22FB, up until recently I didn't know that there was such a distinct difference in tank monitor options that were used in various model years. We have MicroPulse sensors, which do not work well at all...and after reading discussions on the subject seems to just not be capable of working well. I am sure that on a RV/TT with 40G holding tanks you can accept less accuracy, however the tanks on a Sport are small enough that losing 1/4 tank of visibility does matter. This came up as in our most recent trip we went from having a monitor report the gray water tank as being 1/8 full to the shower having standing water and the monitor reporting full...
I see that the LevelSee monitors are are superior, I am curious if anyone else has done this on a 22FB. Getting adequate access to the tanks is the challenging part, sticking the LevelSee monitors on shouldn't be overly difficult nor should the wire splicing, etc. I have tried searching for any threads on the subject of accessing the tanks on a 22FB with no luck.
Hopefully someone has approached a similar task, either to repair a tank, valve, etc and can share some wisdom on the best approach to access each of the 3 tanks.
SilverHouseDreams is offline   Reply With Quote
Old 06-20-2018, 11:22 AM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
I have a lot of experience with MicroPulse and while I have hated them in the past, after recalibration and replacing sensors, the system is very accurate. I suggest before you go through the headache of configuring a new system, take the time and methodically maintain your MicroPulse.
Here is a link to the manual with all the calibration procedure (hint: follow the directions exactly, they are confusing, I had to do it 3-4 times to get it right):
http://www.catconproducts.com/pdf/Mi...itorManual.pdf
Good luck!
vintagemotor is offline   Reply With Quote
Old 06-20-2018, 11:06 PM   #3
2011 22' Sport
Portland , Oregon
Good luck!
Thanks for the vote of confidence, I do wonder if the smaller tanks on the 22FB result in smaller margins of error and this less accuracy since the volume of water (and the associated pressure) is so much less. But I will try a calibration round, but Iíll have to be somewhere with a full hookups of course. I just am not sure I have the desire to try replacing the sensors, as it might be just as much work to apply a LevelSee sensor instead.
micropulse LP sensors GeocamperAS LP Gas, Piping, Tanks & Regulators 4 08-07-2017 07:10 AM
MicroPulse monitor stopped reading water tank Bella123 Land Yacht/Legacy Motorhomes 2 09-17-2014 10:47 AM
Crap! MicroPulse tank sensors misinformed us. jasperkins Eddie Bauer - All Models 22 03-04-2014 03:57 PM
Help With MicroPulse Tank Monitor bike_addict Plumbing - Systems & Fixtures 24 05-12-2013 02:38 PM
MicroPulse black tank sensor PhiDor Waste Systems, Tanks & Totes 16 12-22-2011 04:54 PM
