Old 08-09-2017, 08:42 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
replacement power converter
i installed the PD intello-power 55A converter/charger tonight
why?
it has a 4 stage battery charger unlike the 1 stage that came with the AS22FB.
now my battery will last longer
no MODS needed. the two pieces replace the std ones same same, same front panel
plus they have LED showing which 12V fuse has blown. you can see the LED ( top left) next to the cable screw down terminal for each circuit
Name:	pd power converter.jpg
waninae39 is offline   Reply With Quote
Old 08-11-2017, 09:33 PM   #2
2017 22' Sport
2018 26' Flying Cloud
Brighton , Michigan
Point of information, the '17 22FB comes with a 3 stage converter. Your new one is better then the AS standard spec unit however.
I see 13.6 volts when bulk charging and 13.2 volts when float charging on my AS, it is not a constant flat charge boiling the battery.
Rivet Rocket is offline   Reply With Quote
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Power Converter/Charger Replacement 10Smiles Batteries, Univolts, Converters & Inverters 56 07-27-2012 02:01 PM
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
