Old 05-09-2019, 08:26 AM   #1
2018 22' Sport
Replace Outside Step?
Anyone replaced their outdoor step with a more useful option? No issue with mine except it seems the space could also be used for additional storage with a little thought. I know weight & balance are always a factor. Keeping an eye out.
GasStream is offline   Reply With Quote
Old 05-10-2019, 04:31 AM   #2
2019 22' Sport
Waynesville , Missouri
How would you get into your camper if removed? I was just at a site with a grade down from the road. It was like 2.5 feet to get to the step. If it wasnít there it would have been a stretch up to get into the AS. My entry is toward the rear of the camper though. If yours is at the front, you could avoid my thought about it all.
DAVSCH is offline   Reply With Quote
Old 05-11-2019, 09:31 AM   #3
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Not getting this idea to compute. Remove it altogether? Or remove and use a portable step that is carried elsewhere? Then use the space where the step was to attach a storage box?
The rear door on the 22 is always subject to being backed into a space where the ground slope will make the door entry threshold too far off the ground for most to use it without a step. Maybe rethink this a little. Storage is important but not at the expense of egress safety. A portable step will likely lead to more issues than it solves.
(my 2Á worth - and worth every nickel)
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 05-14-2019, 11:05 AM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
does the folding step on higher end models fold up more , and use less stored height than the simpler one on the AS22FB?
they seem to be made of aluminum and not stamped steel
waninae39 is offline   Reply With Quote
Old 05-16-2019, 06:38 PM   #5
2018 22' Sport
I’m thinking there could be a way to make a dual purpose step that also had some storage space. Maybe for shoes, chocks, or tools. Just wondering
Old 05-16-2019, 11:55 PM   #6
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
We love this step, the AS step never comes down now, the long first step is easier to step down to.
https://www.amazon.com/High-Country-...r+step&sr=8-19
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 05-20-2019, 03:50 PM   #7
waninae39's Avatar
2017 22' Sport
NCR , Ontario
does anyone have the AS part number for the folding alum step seen on higher end model
with the 3" lift kit, my other half would like to get the two step alum model rather that the one step steel model we have in the as 22FB
Old 05-20-2019, 04:50 PM   #8
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I welded metal grate on my step as a place to keep muddy shoes off of the ground. The depth is about 12" with a metal lip.
Steamy1 is offline   Reply With Quote
Old 05-20-2019, 05:00 PM   #9
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i'm getting this 3 step lipper 432696 off amazon
its 27.5" wide, the same as the under door frame
the stick is ONE step is 26" wide, but if you look under the steps you see that AS has given you more room for a wider step
with the 3" lift kit it's 19" down from the As22Fb floor
this 3 step model looks like a good fit
Name:	lippert 432696.jpg
Old 05-20-2019, 05:58 PM   #10
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Here is the airstream step...
http://odmrv.com/catalog/index.php?m...roducts_id=204
wulfraat is offline   Reply With Quote
Old 05-20-2019, 06:11 PM   #11
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
This is what I purchased recently to replace the original steps I crushed by running the curbside in to - well, a curb.
Fit perfectly in the 4 holes from the original stairs on my 2012 27FB.
I did need to use my truckís spare jack and a block of wood to hold it up to the trailer and instead of using the bolts that came with it, I reused the original bolts (undamaged) to screw upward in to the threaded collars that receive the bolts from underneath.
I donít see any storage opportunities.
https://www.etrailer.com/RV-and-Camp...24EXTALC1.html
Old 05-21-2019, 04:47 PM   #12
2019 22' Sport
Fairhaven , Massachusetts
After having the 3Ē lift kit installed, the step was uncomfortably high getting in and out of the trailer. I purchased a 2 step folding steel stair unit from Amazon and removed the old single step and installed the double step. The width was the same, but I had to drill two new rear holes in the new unit. I used the old stair set frame as a template for the new holes. I used a small hydraulic jack to hold the new stair set in place while I bolted it up.
ID:	341327   Click image for larger version
davincent is offline   Reply With Quote
Old 05-24-2019, 04:02 PM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
I had to order the Stromberg Carlson SMEX-24-29 Hickory Springs Extruded Aluminum Step-Double, 9"
its a two step unit
11.5" high when folded and 14.75" when extended as measured from under the floor mounting point
the lower step sticks out 19.5" from the front the side of the As
the three steps unit are too high folded for my as22FB, thus i had to return it
Name:	Stromberg Carlson SMEX-24 double options.JPG
ID:	341526   Click image for larger version
Name:	Stromberg Carlson SMEX-24 options.JPG
Old 05-24-2019, 09:58 PM   #14
waninae39's Avatar
2017 22' Sport
NCR , Ontario
its a two step unit
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by step how to replace a '69 Airstream wing window thesignlady Windows & Screens 26 04-06-2016 05:46 PM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
