Old 10-22-2015, 01:38 PM   #1
2008 19' Safari
Toronto , Ontario
Removing the privacy divider in the 19' Bambi
I'm having a heck of a time getting the folding privacy divider out of the track. I just want to remove the whole thing. Is there a trick to this? Thanks in advance.
oscarb57 is offline   Reply With Quote
Old 10-22-2015, 02:10 PM   #2
Long Island , New York
Maybe you have to unscrew the track, free one end up, and slide the divider out of the track? Just a guess . . .
Old 10-22-2015, 05:34 PM   #3
Johnco's Avatar
2006 19' Safari
Anaheim , California
You have to remove the three screws that hold the divider to the wall, one at the top, one in the middle and one at the bottom. Once those are out you can pop the track out of the bracket. At that point you can slide the divider out of the track.
Johnco is offline   Reply With Quote
Old 10-22-2015, 07:38 PM   #4
2008 19' Safari
Toronto , Ontario
Thanks for the responses. I already had removed the three screws (that was easy). But I found the track jammed tight into the wall bracket at each end. I wasn't sure if I should be just forced out (i.e. start looking for my hammer) , or if that was going to do any damage. So it appears that is exactly what needs to be done. I'll let you know the results.
Old 10-23-2015, 09:59 AM   #5
2008 19' Safari
Toronto , Ontario
It worked. The track was just tight and friction fitted. Thanks for the help.
Old 10-23-2015, 11:03 AM   #6
2004 19' Bambi
Cincinnati , Ohio
I have a 19 foot Bambi. Taking anything apart in it is a challenge as it is so solidly built.
Richard Kern is offline   Reply With Quote
Old 10-23-2015, 05:55 PM   #7
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
We replaced the solid bathroom door with our privacy curtain. No more door opening into the kitchen. Yea!
StreamDog is offline   Reply With Quote
Removing folding privacy wall in '09 Bambi kathyek Upholstery, Blinds, Walls & Interior Finishes 5 01-13-2014 01:36 PM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Divider boxes for glassware Jammer Stella's Kitchen 6 10-25-2010 08:50 AM
Driver's window divider Turtle One Windows & Screens 0 01-04-2009 06:16 PM
bathroom/living room divider? codybear Cabinets, Counter Tops & Furnishings 18 08-25-2006 01:30 PM
