Old 03-11-2014, 11:04 AM   #1
2008 19' Bambi
Houston , Texas
Reefer Questions from the new guy
Howdy Gents,
My name is Anthony and I recently became the owner of a 2008 19' Bambi AS. I have read the owners manual and am doing a run thru of all major systems on board. All pilot lights fire up automatically and everything is receiving 12v power. I am doing all this in my drive way, fyi, so no 110v.
I cranked up the reefer yesterday, and put the red switch just inside the main door on the left in the UP position. It lite up and the front of the fridge is set to operate on gas. The test light is not illuminated. All seems well. From the outside access hatch, the pilot light is blue, the fan is blowing.
I don't understand the correlation between the fan and the reefer? How long does it take to slightly cool the reefer in order to confirm this system works? My MAIN concern was that there was a plastic smell coming from the air the fan was pushing outward. Kinda of like burning plastic/dust/i dont know... This trailer as never been used before, so there is a good chance that this is the first time the fan has ever been run.
What do yall think, should I just let it run for a bit, and burn of this smell, or is there a concern here and something I need to investigate? When do i switch from the reefer setting, to the SW Fan setting?
Thanks yall, hope to learn a bunch, and one day contribute in return to this forum! Cheers!
FishHuntTX is offline   Reply With Quote
Old 03-11-2014, 11:49 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It takes sometimes 12 hours for an RV refrigerator to get to the correct temperature.
Then the temperature varies with the ambient outside temperature.
It might cool to 34 degrees in mild weather and may only cool to 40 degrees when it is hot.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-11-2014, 11:51 AM   #3
m.hony's Avatar
2013 30' Classic
Put some ice cube trays in the freezer compartment.
When the ice starts to form it is time to put the groceries in...
The refrigerator seems to get to temperature a lot quicker after dark than in the daytime.
Rule of thumb- turn on refrigerator the evening before you head out on a trip.
TAC #MS-10
Airforums #70955
Old 03-11-2014, 12:02 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
It does take a good while for an RV heat absorption refrigerator to get to operating temperature. I assume the fan that you are referring to is the little computer cooling fan that helps the refrigerator coils stay cool. A plastic smell is probably not a problem. A burning plastic smell is.
Also, I mention this only because you refer to yourself as new to all of this, you do not have to have a 30 amp RV outlet at your house to plug the trailer in. As long as you are not using the air conditioner or heat pump, you can just take an adapter and plug into any 15 or 20 amp outlet and run all other trailer functions including charging the coach batteries.
Brian
SuEllyn & Brian McCabe
Old 03-11-2014, 12:38 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Welcome fishhunt.
Feel the aluminum fins inside the fridge. They are the first thing to get cold.
I might also recommend a remote thermometer. You can get one for $10 from Walmart. This allows you to monitor fridge temperature without opening the door.
RV fridges are not like house fridges. You get marginal cooling especially in hot weather.
Dan
Old 03-12-2014, 09:07 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Once our fridge gets cold it will keep ice-cream and ice cubes in the freezer even in 100º. I don't consider that marginal.
Ahab is offline   Reply With Quote
Old 03-12-2014, 10:22 AM   #7
1974 Argosy 20
Kooskia , Idaho
A little smell if brand new is not uncommon.
The fan is controlled by a thermostatic switch on the fins or pipe in the upper refrigerator cabinet. You will see it if you look for the wires from the fan. The fan will run most of the time when the refrigerator is on Propane, a little less when on line power.
The refrigerator takes about 4 hours to start to cool down. The first place you will feel the cooling is on the floor of the freezer compartment, not the fins of the refrigerator compartment.
Old 03-12-2014, 12:00 PM   #8
m.hony's Avatar
2013 30' Classic
Yes, the RV refrigerators are adequate and do perform the task of refrigerating our groceries- they just don't ever get as cold as the refrigerator in the house does-
We still have ice cubes and unspoiled food...
The food on the top shelf definitely gets colder- sometimes bottled water has ice crystals in it.
It's all good.
TAC #MS-10
Airforums #70955
Old 03-12-2014, 12:21 PM   #9
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
i thought you meant
Colorado tourism
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 03-12-2014, 12:37 PM   #10
m.hony's Avatar
2013 30' Classic
Colorado tourism?
Hmmm...
I don't get it...
TAC #MS-10
Airforums #70955
Old 03-12-2014, 01:15 PM   #11
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I think it also helps if your product that you are placing in the fridge is ice cold. Chunk it in an ice chest and ice down prior to putting it in the fridge. Also helps to have a real clear idea of what you want out of the fridge before you open the door. This is not the time to be "looking around". For this reason, we keep a separate drink cooler in the bed of the truck.
Cannonball is offline   Reply With Quote
Old 03-12-2014, 01:20 PM   #12
m.hony's Avatar
2013 30' Classic
What he said.
We sometimes take 3 coolers for ice, drinks, and meat.
TAC #MS-10
Airforums #70955
Old 03-12-2014, 01:51 PM   #13
2008 19' Bambi
Houston , Texas
All great advice Gents, thank you. I have purchased a remote thermometer and will fire it up and see what happens!
The red switch just inside the door.... When do I switch it to the fan mode and not the up position, reefer mode?
Old 03-12-2014, 01:54 PM   #14
weirdstuff's Avatar
2018 23' International
San Diego , California
Wow, this thread is not at all what I thought it was gonna be about.
weirdstuff is offline   Reply With Quote
Greetings and hello with questions rodsterinfl Member Introductions 36 02-24-2012 03:02 PM
New guy with a few questions... Bone Batteries, Univolts, Converters & Inverters 8 02-10-2012 10:34 AM
Newbie/lurker first post with questions airfun Member Introductions 14 02-07-2012 02:39 PM
Noob with tons of questions! 8string Full-Timing 14 07-20-2011 12:55 AM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
