Rear Camera Flooding
I have a 2019 Sport 22FB. The factory installed rear camera has a lot of water in it from all the rain we received this spring. My rear view from it is just a bright, blurry blob. First, someone at AS should have submerged those things to see if they leak, ‘cause they do. Second, removal and drying out. It is attached to a bracket with hex screws. OK, I can remove screws. The wiring goes into the AS through a rubber ‘plug’. I can remove a rubber plug. The question is, is the wire connector for the camera on the other side of the plug, or is the connector far from the hole, which would require removing panels? If the connector is right at the hole, I can remove it and dry the camera out, but if it’s far down the wall it looks like AS is going to do some warranty work. Anybody ‘been there, done that’ with the camera?
