Old 09-23-2017, 06:42 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
portable, easy to remove washing drying rack
my SO wanted a drying solution. Not all camp ground have trees and or nicely spaced strong posts to run a clothes line
so i built one after finding a special part in a boat store. its the rubber clip that screws into the bumper and the bottom horizontal pole pivots on it
  • using 1' square alum stock
  • drill holes are solid 1/4" alum bar stock
  • get PVC pipes that has ID just over 1/4"
  • cut them all to the same length
  • drill holes into the end of the bar stock so that hitch pins fit
  • put the solid bar stock into the PVC pipe
  • clip the hitch pins onto one side
  • from one end start align the solid bar on the others side
  • now you have what looks like a ladder
  • since all the items are cut to the same length, the ladder is fairly rigid
  • screw the rubber mount onto the bumber
  • push the bottom of the ladder onto the rubber mount
  • now decide what angle you want he rack to be at when in use
  • i used aircraft SS cable with turnbuckles
it all comes apart and stores as just a bunch of linear stock
here is what it looks like
Name:	20-laundry drying rack-mounted.jpg
ID:	295406   Click image for larger version
Name:	21-laundry drying rack-mounting.jpg
Name:	22-laundry drying rack-AS rear mount.jpg
ID:	295408   Click image for larger version
Name:	23-laundry drying rack-AS rear bottom swivel.jpg
Name:	24-laundry drying rack-AS bottom swivel only.jpg
ID:	295410   Click image for larger version
Name:	25-laundry drying rack-rear with rack removed.jpg
waninae39 is offline   Reply With Quote
Old 09-23-2017, 07:10 PM   #2
1979 23' Safari
Wayland , New York
That's a lot of nicely done drying rack.
Old 09-24-2017, 09:04 AM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is what the rack looks like taken apart
all items expect the two long poles fit into the external storage area
Name:	30- drying rack knock down parts.jpg
Old 09-24-2017, 09:59 AM   #4
2007 22' International CCD
Excellent idea and write-up. Thanks for sharing!
rmkrum is online now   Reply With Quote
Old 09-24-2017, 12:36 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is what the rear of the as22FB looks like after the drying rack is taken apart.
the rubber swivel mounts are invisible against the bumper
the two white plastic cable clamps are visible, but they are very small
3m tape atop to stop water leaks
that was an install condition from my SO
Name:	as 22fb rear.jpg
portable clothes drying rack waninae39 2005 and newer - Bambi all models 1 09-04-2017 05:45 PM
Easy Trailer Washing John&Vicki General Repair Forum 1 07-09-2017 09:29 PM
drying rack for 2007 Safari 25' jetjocky Off Topic Forum 2 03-24-2012 11:55 AM
What do you use for a dish drying rack? WineStream General Interior Topics 29 12-31-2010 09:56 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
