Originally Posted by Tylertexan
Ok my fellow airstream lovers,
1. I have rivests popping out over the entry door and fridge leaving ugly holes. My problem is I have been to the Airstream website and they offer about a thousand different kinds of rivets(ok exageration) anyway does anyone know which to get.
2. Right now I use a small microwave on the table, I would like to find one to mount somewhere but I wonder whats the best choice is and where to mount it, you guys know the space issues in our little beauties . Help!
You need to use "Olympic rivets."
To use them, you will also need a decent pop rivet gun, and a tube of Vulkem sealer.
You will also need the correct drill bit size for the Olympics, which is #21.
You should also have #30's and #11's handy as well.
We have a drill bit kit that provides all 3.
You should also find out what's causing the rivet failures.
Three things that do cause that type of failure, is lack of proper running gear balance, excessive rated hitch bars, and a heavy duty tow vehicle, and/or a combination of those.
