Old 04-18-2019, 02:20 PM   #1
Sheridan , California
Pano Window Stone Guard Removal
I always dread removing the front pano window stone guards because reinstalling the 1/4 turn screws are so difficult. Had to do it today in order to reinstall a spline on the inside of one of them. Reinstalling the guard this time was easy but I noticed there's a 3/8" long rock crack in the middle of the plexiglass. Cant see it from the outside. Has anyone tried repairing the plaxiglass or do I have to replace the entire stone guard?
Airabel is offline   Reply With Quote
Old 04-18-2019, 04:01 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
You can replace the plexiglass, the frame comes apart after drilling out a couple rivets at each 90 degree corner and removing the straight frame section to allow the plexi to slide out.
Others here have said acetone in the crack will weld it closed.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 04-18-2019, 04:49 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Stop drill the crack and use a syringe of acetone to weld the crack.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 04-18-2019, 06:30 PM   #4
2007 22' International CCD
More detailed:
Stop drill: Drill a 1/16Ē or smaller hole through the plexiglas at the exact ends of the crack to stop it from spreading further.
Acetone weld:
Remove the rock guard if possible, and lay it face down on a clean padded surface. Use a tiny brush or disposable syringe and needle to put just enough acetone into the crack to wet the interior of the crack along its full length.
Donít get acetone all over the place, it will damage the polished surface of the plastic.
Let it sit and dry and it will weld the crack shut. Donít move it until itís fully dry. If you missed some of the crack, repeat the acetone welding carefully.
If there is a haze around the crack, carefully and gently use a plastic headlight polishing kit to restore the surface shine.
rmkrum is online now   Reply With Quote
Old 04-18-2019, 08:17 PM   #5
Originally Posted by rmkrum View Post
More detailed:
Acetone weld:
So what do you fill the two 1/16" hole with? Any chance of just doing the acetone without the holes?
Old 04-18-2019, 08:29 PM   #6
Problem is that the crack will continue to travel without the holes. Keep them small, put a tiny daub of clear silicon caulk in the holes if they bother you.
Old 04-19-2019, 07:22 AM   #7
2017 25' International
Joliet , Illinois
I have used this product to weld pieces of plexiglass together with excellent results. Being very thin it should have no problem getting into a crack.
https://www.amazon.com/Weld-Acrylic-.../dp/B0149IG548
If your having trouble with the 1/4 turn screws you might need to replace the rubber mount. Had a couple of mine go bad and not allow me to turn and lock the screw.
bel73 is offline   Reply With Quote
Plexi front window Stone Guard frjeff Rock Guards, Segment & Window Protectors 37 04-19-2019 11:17 PM
Front Curbside stone guard -Front Sun guard Projet2907 Windows, Doors, Locks & Vents 0 02-06-2018 07:26 AM
Stone Guard Window Gaskets SteveSueMac Windows & Screens 4 08-27-2014 07:10 AM
Spontaneous pano window shatter CanoeStream Windows & Screens 7 11-01-2013 02:55 PM
Window Stone Guard What to do? 05ModPod Rock Guards, Segment & Window Protectors 30 08-31-2006 09:49 PM
